rguest3
Raymond
Florida and Virginia
F-350, F-450, 2022 Bronco, (2) 77 Broncos
To install the ARB Tread Pro with the Accessory Bracket, do you use the ARB TPMK Mount Kit for the Treads or just bolt through?
DoYouBronco
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
Yes you will need the arb tred pro mounts that attach directly to our accessory arm. Stand by for video!
We_Love_Tacos
www.bronco6g.com
2021 Ford Bronco First Edition 2Dr Lightning Blue
Got my Hammer Built gear in and install was easy, I’d definitely recommend two people if you can as it will make the process easier yet. Tyson makes a great product. Zero squeaking now which is great since I’m putting 37’s on here shortly.
DaveInSA
Seguin, Texas
2021 Bronco Badlands 4DR, 2007 Saturn Sky
Mine originally said estimated delivery yesterday. But evidently ups can’t get from Fort Worth to San Antonio in less than 24 hours. So out for delivery today “by 7pm”. Which usually means at 7 pm :(
DaveInSA
Seguin, Texas
Installed. Was really easy to do with the help of another person for positioning the spacers.
Very happy with it.
Now to figure out what to put on the accessory mount...
DoYouBronco
DoYouBronco
Tyson
El Paso
hpbuilt.shop
Very happy with it.
Ford Bronco Hammer Built - Built to Hammer On: Modular Tailgate Reinforcement System hb
Looks great! Thanks for sharing! If you want some extended range the 3 gallon rotopax can really give you some extra piece of mind on those long stretches between stations.
if you anticipate icy/muddy/sandy trails, the Arb tred pros are super useful if you ever encounter a low traction situation.
Stonetree
Ron
Pittsburgh
2021 Bronco Wildtrak
Does anyone know the torque requirements for all the bolts?
NVCowboy
William
Henderson, NV
Ok, Im really interested in getting this to actually just provide more general support for the tailgate as well as help the infamous popping/creaking noises that a lot of people are getting. Mine is just a regular BD though, so I'm really not wanting to look like some kind of off road poser by installing this and not hanging a 37" tire off of it. Decisions, decisions.
Plenty of posers running 37s. Real reason, is how much crap you wanna hang off the tailgate? Me? Probably too much, because gas stations can be scarce out here. There's one trip where running out is a real possibility, and you don't even have to leave the county.
5280Bronco
Denver
Stonetree
Ron
Pittsburgh
+-18lbft for the hinge bolts
Hmmmm....I'm surprised that's all considering it's supporting an entire tailgate and spare tire. Is that because of the Delrin spacers?
What does the service manual say for the outside tailgate hinge bolts and spare tire mount bolts? I think the inside tailgate hinge bolts are 30 ft lb.
@flip ?
flip
Phil
IN
www.ruxerparts.com
Fords
Tailgate Alignment
Inspection
NOTE:
Removal steps in this procedure may contain installation details.
  1. Check tailgate-to-body dimensions.
Adjustment
All alignments
  1. Remove the nuts and the spares wheel.
    Torque: 41 lb.ft (55 Nm)
  1. Open the tailgate about 5 to 10 degrees.
  1. Note down the movement in tailgate due to spare wheel removal. Noted movement due to tire weight should be accounted during final alignment.
Tailgate left and right, up and down alignment
  1. Remove the RH rear lamp assembly.
    Refer to: Rear Lamp Assembly (417-01 Exterior Lighting, Removal and Installation).
  1. Open the tailgate.
    1. Remove the bump stop.
    1. Remove the bolts and the striker.
    1. Loosen the bolts.
      Loosen:
      : 2 turn(s)
    Loosen:
    : 2 turn(s)
  1. Adjust the tailgate as required.
  1. Tighten the bolts.
    Torque: 30 lb.ft (40 Nm)
      Torque: 17 lb.ft (23 Nm)
    1. Install the striker and the bolts.
      Torque: 18 lb.ft (25 Nm)
    1. Install the bump stop.
      Torque: 22 lb.ft (30 Nm)
  1. Install the RH rear lamp assembly.
Tailgate in and out alignment - on hinge side
  1. Remove the fasteners and the tailgate hinge cover.
  1. Mark the location of the tailgate hinge to aid in installation.
    Loosen:
    : 2 turn(s)
  1. Close the tailgate.
Tailgate in and out alignment - on latch side
      Loosen:
      : 2 turn(s)
All alignments
  1. Install the spare wheel and the nuts.
  1. Inspect the body-to-tailgate door dimensions.
  1. Install the positioned aside and removed components.
