Home made custom wheel center caps
56F100
john
Venice, FL
56 Ford F100 with 30K original miles
I found these Bronco center cap emblems on Etsy. They have just about any car or truck center cap imaginable. They also can make them in many different diameters to fit your center caps. I decided to paint my white Fifteen52 Analog HD center caps black and insert these emblems. Easy to do and it makes the Fifteen52's look even more retro.
Ford Bronco Home made custom wheel center caps wheel center 1
Ford Bronco Home made custom wheel center caps wheel center 2
Ford Bronco Home made custom wheel center caps wheel center 3
stickshifthappy
RVA
Ford Ranger, 65 Mustang
I'm digging those with the steelies, a nice retro look !!
56F100
56F100
john
Venice, FL
Thanks. I forgot to mention, the company is AutoWorldArt.com. Center caps for any vehicle.
daddycreswell
Josh
Tenneessee
2013 Raptor, 1973 Bronco
That's sharp.
MayhemMike
Mercury
I never liked the Steelers however ,your caps changed that. Looks fantastic.
TCB-1
Doug
Kansas
'23 Black Diamond, '06 Scion xB, '61 Impala
Those look GREAT!! I'm going with those same rims and now I have some customizing to do!
Bruno
Bruno
Montclair
For my 16" steel wheels, I was searching and searching for a traditional OEM looking cap - then I realized I cant add caps to the steel wheels....
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
Hey, that looks great- excellent creativity!
Bigred86
Curt
Thurmont, Maryland
2022 Ford Bronco, 2016 Harley Davidson Sportster48
I may have to copy you with mine! Good idea! What was the hole in the center cap for? Did you just use the adhesive that came on the center cap overlay?
56F100
56F100
john
Venice, FL
I drilled the hole in the center cap to get them off the wheel. (Similar to what Porsche does with their center caps). I could not get them off of the Fifteen52 without possibly chipping the powder coating so I drilled the hole and used an L-shaped tool and off they came. Now, they'll stay put for good. Adhesive was on the back of the emblems. They're stuck on very well. Great product.
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
Center cap with emblem looks awesome!
How did the tire shop mount and balance your tires on the wheels? The center cap has to be removed for them to install the tires.
Couldn't you just remove the tire and wheel and push the center cap out? No drilling.
Maybe even a trim tool to remove center cap.
56F100
56F100
john
Venice, FL
Yes, of course. The tires were mounted before center caps were put on. Once the caps were on the wheels I could not get them off. Tried everything, including trim tool. They need to be pushed out from behind but I did not feel like taking wheels off. Holes are covered by emblems and will never be an issue.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Those look really cool! Thank you for sharing.
