- Jason
- Jan 24, 2021
- 12
- 834
- 1,464
- Fort Wayne, IN
- Website
- www.instagram.com
- 2021 Bronco
- Outer Banks
For this to be a plug and play installation, your Bronco needs to be equipped with the lighted mirror.
Visor Assembly W/Garage Opener - part number : M2DZ-7804105-CA
Here are the install instructions from the FSM (thanks @D2dhanover)
I used a trim tool to pop the cover off. The bolt is 7mm
For informational purposes, here is how the visor is wired (thanks @D2dhanover)
Edit to add remote programming instructions:
From HomeLinks website:
Programming Instructions
For first time training, press and hold the two outer HomeLink® buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.)
This took maybe 15 mins to install and program.
- Position the hand-held transmitter 1-3 inches away from the HomeLink surface (usually located on your visor, overhead console, or mirror), keeping the HomeLink indicator light in view.
- Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
- Press and hold the trained HomeLink button and observe the indicator light.
- If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
- If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
- At the receiver (motor head unit), locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the device owner’s manual.
- Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step.
- Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
