PghBronco
Pittsburgh
Disclaimer: It may look like it via video/ pictures but I am not a professional I do not even constitute as a amateur. Without further ado, enjoy and feel free to point out flaws or advice this was my first time ever attempting anything like this. I like to show my mistakes as a way to show people aren't perfect, you can fix it. I am not these "influencers" who plug and play their mods etc. Give me an example or idea and I can attempt to make it work.
I wanted to challenge myself and prove to others that you can do it also.
Earlier this month a member posted a link: https://srqcustoms.com/product/ford-bronco-subwoofer-enclosure-with-grille/
I saw this and wanted to see how much it was, 600$! and me being disgusted at the prices for aftermarket parts and accessories for the bronco.... LETS MAKE A THING!!!
-Just by looking at it i guessed it had to be 6 layers of 3/4 or 1/2 mdf. I picked up a 8x4 sheet of 3/4 inch mdf cut that down to 2 feet long sections to make it easier to work with. $50 thus far.
Ford Bronco I made a thing! Custom sub box build complete! 8785002F-5FF9-4B7A-9465-324CE2CC7321
I had to remove, rear tailgate cowl, cargo floor, the floor seat cowl(???) soft top latch, unplug the keyless antenna, 12v and light, right rear trim panel, Now lets get the rough measurements/ templates. Shoutout to @Ksjrb03 for attaching the PDFS for removal of the trim.
NOTE: I will address the box build by layers, 6,5,4,3,2,1. Layer 6 being the outer most where the sub screws into, One being the layer closest to the tire. Each layer was glued and nailed with 1.2 in finishing nails.
The overall length of the box is around 2 feet long. On the site they said (dimensions taken down?) 12x10x24 if I recall. That gave a an rough idea on the layers and whatnot.
Trim prep: I took a 3/4 drill bit and drilled out the plastic welds(?) holding the storage cubby in place. and then I pulled out the fabric. (Afterthought do not pull that off. Leave it.)
Layer 1: When measuring this layer I found it slightly difficult to get a good reference point to measure, looking at the example i can see the far left bolt so I knew the box started at that point or just passed. I started my box there as a good reference point, all the way to the left. The example shows at least an inch or so, someone with better experience could use that space to mount an amp. I unplugged some of the plastic pins to give more space and stuffed them into the frame. You can plug the keyless antenna in as well. I marked on the frame of the vehicle every 2 inches to help guide my template around the wheel well The first prototype (sub box mark 1 ) my cuts were not straight thus I had to use a jigsaw which provided an ugly box. I was able to see where my original marks where and where I could add some width, length etc. The top right of the box you have to cut a 45 degree to clear a ground wire.
Ford Bronco I made a thing! Custom sub box build complete! B605E659-8798-4E9D-81F3-F323EFA948B9
Layer 2: This was cuz exactly like layer one but no more 45 degree cut on top right. I cleared the wire. I used my adjustable angle (R.I.P she was a good tool😢) set at 3/4 of an in for the boarder to glue and nail. I used the jigsaw and cut it out.
Ford Bronco I made a thing! Custom sub box build complete! 9AD5CCBF-8B93-4D38-AA3B-DCA8CC4A2C84
Layer 3: The picture is a mistake on sub box mk1. I needed more material on this layer to copy the example and layers 4,5,6 will be narrower (10 inches wide) I mounted the MK1 and stared at it for a couple minutes, looked at where I can improve. This is where MK1 dies😢. Now on to MK2.😁
Improvements to MK1: layer 1 i made it thicker on the angle from the left side you can see a notch I cant remember the thought process on that, But all my cuts came from a circular saw and the testy areas I used my jig saw. Then with the help of my brother he recommended cut a rough shape of the boarder at 3/4 then use the router to match the rest. Again Layers 2,3 are the same.
Ford Bronco I made a thing! Custom sub box build complete! 76CD5321-E9DF-4A7E-BF56-6214852E0BD1
MK2 Layer 3: I routered this layer out and remembered I needed more at the top of the box because layer 4,5,6 are the same. Thankfully I kept the scrap and was able to use wood glue and filler to salvage this layer. What I learned here is to go slow and test fit as many times as you can.
Ford Bronco I made a thing! Custom sub box build complete! 2F455EAA-CFD1-4A2E-94C9-73592EBA0C4C
Ford Bronco I made a thing! Custom sub box build complete! EAAE964E-87FE-4291-82AB-AF8894824ADF
Layer 4: This is where I realized that 3/4 was too thick. The sub the example uses is a kicker L7T it has a minimum .2 cuft with a max of .75 cuft. I did some rough calculation and I think I got .165. So in order to test I wrapped the box in two layers of trash bags then filled it up. I would need at least 5.66 liters of water. I was able to get 6.03 liters inside. I went ahead anyway and the next two layers I had a 1/2 wall thickness. Now layer 2 and 3 are at 3/4 thick. Home depot has a 1/2 by 2 inch router bit I grabbed for 22$ Which is fine. I needed a new right angle anyway. Thinned out the wall I am above the minimum so it will only increase the sound. On the bottom of the box you can see I adjusted the angle which also provided more space inside. Note: Poly fill will not work in this case, that will only work if you are below minimum to "trick" the sub into being in a bigger box.
Ford Bronco I made a thing! Custom sub box build complete! 81A9CA24-45BE-4138-A6D8-5FD3C770A2FD
Layer 5: Same as layer 4. Once this layer was on I went ahead and got my sander out and sanded down the outside of the box and inside to clear up any random cuts to make it nice a smoothish.
Layer 6: Exactly like 4 and 5. To mount the sub I went ahead and attempted to guess where that cubby was located in order to mount it where that was. It prove to be a little difficult to get the right spot. Looking at the example that one isn't mounted close either. I went ahead and mounted it 1/2 in in from the sides. To my surprise that was a pretty reliable method. The sub is 75% exposed. Before I mounted this layer I flipped it over and routered out 1/8th inch under the box to increase cuft. I sprayed Polyurethane (4 coats) around the entire box for moisture and water repellant ( should have painted it first then poly). I mounted the Meta terminal just to the left of the sub box. I considered using terminals that screw into the side having a minimal footprint but these added 1/2 length to the outside of the box. The metra terminal was flush. Pilot holed where the sub would mount and its ready for nail and glue.
Ford Bronco I made a thing! Custom sub box build complete! 72C0B5F2-F81E-4B71-A3C6-9EE00E493FE5
Mounting: On the frame of the vehicle there is a spot where I believe the B&O sub attaches to I used a 5/8 bolt with a nylon nut to attach the box. Prior to attaching the box I used Killmat (really good product) around the wheel well, under the wire, everywhere that I thought the box would be sitting against the metal. I also threw some in there for good measure just because.
Ford Bronco I made a thing! Custom sub box build complete! 7186D2C4-3EA1-4E9F-9AC3-66B738A2B058
Ford Bronco I made a thing! Custom sub box build complete! 6912CB30-A77C-45B1-9486-E2908095D5EE
Wiring: What a pain in the as$ so! I had to run 18g wire from the kick/ wheel speakers. (pro tip: when in doubt Crutchfield it out.) the trim isn't hard to remove. I got a poraxy trim kit off amazon a while ago for 20$ and its already paid for itself. If you don't want that there is a trim removal tool that idk how else to describe it, at the end is a U its metal and around 8 inches long that was a huge help especially during the rear trim removal. I was able to reach in with said tool and apply pressure around the clip. I ran the wires with ease. I had a choice, Run the amp power wire from the engine bay across and enter the car on the passenger side or just run it up straight down the driver side. The driver side speaker panel is a PITA with the foot rest. There is a rubber plug which I drilled a 3/4 hold and pushed the wire through. I also used the same hole for the remote on switch. Luckily I had the add a fuse for my oracle lights so I spliced into that. Each light draws <0.1a and so far no issues.
Amp: I went with JL MX300/1 Marine grade (https://www.crutchfield.com/p_13698406/JL-Audio-MX300-1.html) its small, so I can put this anywhere I really want. Ideally I tried to do it under the plastic trim from the rear to the seats. I tried to mount it there and it sort of worked and the trim did not lock into place. I decided to mount the amp in the storage bin under the rear panel. I considered under the rear seats as well, it looked like this would fit with a ABS sheet but I did not try, I was happy with the bin. Ran the wires under the rear trim board and 12g wire into the terminal with 12g wire going into the sub. The only down fall of this amp the adjustment knobs are under the unit and covered by a rubber panel. So you need to set up your sub then attach the panel then mount to your spot of choice. Looking at the box I noticed there was a decent amount of space on the bottom right, It was almost 9 inches deep, Hindsight 20/20 i bet the amp would fit there. Just killmat/ poly around that area to stop the rattle.
Assemble the trim: I found out that I needed to sand down the top of layer 6,5,4 in order for the trim to fit. I was 1/8 inch too thicc. No big deal for the sander and Dremel. The example shows that around one corner.
Protection panel: This was a 10x10 ABS 1/4 thick I had left over. I lined up the top of the ABS to the top of the trim before it turns inward. I measured where the hole was starting at the bottom and that's where the start of my slots would be. Using that 2 inch long router bit (too lazy to change, you could go smaller) and my new 90 degree angle I drew straight lines and just made the width of said ruler wide (1 inch to 1.3 wide) for spacing in between the lines. It came out rough, I intended to make the edges smooth with a shaping bit. The first slot worked well. The second, I must have sneezed and it caught screwing it up. That's okay, I plan on doing a 3d print version.
Ford Bronco I made a thing! Custom sub box build complete! 83A5B8D8-EDAD-4AD0-8E04-E53CE7BE4EC6
Ford Bronco I made a thing! Custom sub box build complete! BF9222D1-B947-47C6-A27A-AE166A4DC16C
And there we have it folks. That's my journey on making a thing for a fraction of the price:
MDF:50$
90 angle: 12$
Bit: 22$
Bolts, nuts, electrical equipment: 50$
Beer: 30$
Amp:250$
Sub: 250$
664$ total complete.
whereas you buy it
Box 600$
Amp:250$
Sub:250$
1100$
The cheapest and quickest method would be getting the B&O box from the dealer and upgrade that.
Overall this was a nice upgrade and plenty of sound/bass that id expect from an 8 inch sub. Its not gonna rattle the doors off however, there is a notable difference when its plugged in and when its not. Also don't judge my messy shop pics. Its organized chaos. :D
I appreciate any and all feedback.
splytsecond
J
Chicagoland
cars
i appreciate the beer budget built into the build. essentials.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
My storage bin in back STAYS wet. I don’t put stuff in it,
PghBronco
PghBronco
Pittsburgh
It's not ideal, it's at the top right lip should midigate water and it's marine grade as well. I'm really thinking about moving it to lower right corner by the box.
PghBronco
PghBronco
Pittsburgh
Nicely done.
I would suggest fogging out the wood with black/gray spray paint behind the protection panel.
That's a mistake. I needed to paint then poly the box. I did a quick search and it said paint won't adhere to poly. Although I could try plasti dip
Erock
US
2018 F150 Alpine edition
So, what would you charge to build the box for someone else? Don’t get me wrong, I love seeing folks build their own stuff… so in no way being critical. I try to build as much of my own stuff as makes sense to do so. Just wondering where your box would come in, cost wise, compared to the shop built one.
As a side note… I have an extremely tough time pricing stuff that I build. My price would usually be higher than most of the ones you can just buy… I’m probably overvaluing my time 🤑
Edit: Forgot to say, nice job.
Rjhoefar
Roy
2022 bronco badlands
I've got the B&O system. Just had a new sub put in the existing enclosure and they mounted a new amp behind the box. Much better sound over the original speaker
Martiin
Martin
Alamo tx
2021 bronco
Ford Bronco I made a thing! Custom sub box build complete! 07E46B93-B549-432D-BB37-79C2B1F74D72
MDF:50$
90 angle: 12$
Bit: 22$
Beer: 30$
Amp:250$
Sub: 250$
whereas you buy it
Box 600$
Amp:250$
Sub:250$
1100$
I had a friend send me photos a few months back of an enclosure like this. I've been wanting to build one but just haven't had the time to. I'm running 2 8in sundown sub 800rms each on two ported boxes and I have to say the are laud. The only draw back of my current set up is the boxes do take up space with is why I want to build something like this.
You did a really good job at replicating that box.
Jmart52
Jason
Socal
2022 Wildtrack, 76 Bronco, 64 f100 etc
Fyi the SRQ comes with the sub
JJ_Gecko80
Juan
Ohio
2022 Ford Bronco Big Bend
Looks great, good job!
