- Jake
- Oct 22, 2021
- 446
- 985
- 715
- West Palm Beach, FL
- 2022 F-150 RCSB 5.0
- First Edition
Hey All!
Injen Technology has dropped a BUNCH of Bronco Performance Parts for the 2021+ Ford Bronco’s!
Let's start with their exhaust! With one base system and 3 different counterparts, there’s a kit for everyone, whether you’re looking for just an axle-back or a full cat-back system!
INJEN FULL STAINLESS STEEL EXHAUST SYSTEM SES9300
Fits ALL 2021-2022 Ford Bronco 2.3L & 2.7L, as well as both 2-door and 4-door models without modifications.
- High-tuck design for increased ground clearance
- Manufactured from huge 3.0in (76mm) mandrel-bent 304 stainless-steel - tubing, which reduces restriction providing increased airflow and performance
- Increase Throttle Response and Decreases Turbo Lag
- Dyno Proven power increase of 10 HP and 11 Lb.-Ft. of torque at the wheels
- Tip extensions can be removed for improved departure angle
- Designed and manufactured in Pomona, CA
Check it out the full Catback here!
Injen Stainless Steel Cat-Back Exhaust System (2021-2023 Ford Bronco 2.3L / 2.7L) - SES9300
Check out the Axleback version here!
Injen Performance Axle-Back Exhaust System (2021-2023 Ford Bronco 2.3L / 2.7L) - SES9300AB
INJEN SES MUFFLER DELETE KIT - SES9300MD
- Fast and simple bolt-on that provides increased approach and departure angles
Check it out here!
Injen SES Muffler Delete Kit (2021-2023 Ford Bronco 2.3L / 2.7L) - SES9300MD (INJ-SES9300MD)
Let move on to their Intakes!
Injen Evolution Cold Air Intake System
Dyno Proven gains of up to 26 hp and 27 lb.-ft. of torque (2.7L).
Dyno Proven gains of up to 13 hp and 13 lb.-ft. of torque (2.3L).
- Massive intake tube that tapers down from 5in OD to 3.5in for increased airflow
- Large forward-facing inlet is twice the size of OE to maximize incoming cool air from behind the grille
- No Tune Required - Designed to work seamless with the stock calibration
- Clear inspection badge allows you to quickly check the condition of your air filter.
- Made in Pomona California, USA
- Injen Technology Limited Lifetime Warranty.
Check out the Intakes here!
2.3L : Injen Evolution Cold Air Intake System - Oiled Filter (2021-2023 Ford Bronco 2.3L) - EVO9300C (INJ-EVO9300C)
2.7L : Injen Evolution Cold Air Intake System - Oiled Filter (2021-2023 Ford Bronco 2.7L) - EVO9301C (INJ-EVO9301C)
Both kits are also available with a Dry Filter!
2.3L : Injen Evolution Cold Air Intake System - Dry Filter (2021-2023 Ford Bronco 2.3L) - EVO9300 (INJ-EVO9300)
2.7L : Injen Evolution Cold Air Intake System - Dry Filter (2021-2023 Ford Bronco 2.7L) - EVO9301 (INJ-EVO9301)
Injen currently has quite the selection of parts in development at the moment, including an Intercooler and Charge Pipes.
We will be watching closely as these draw close to release, hoping for some more impressive dyno gains.
According to Injen, these are expect to be released within the next few weeks!
Of course, if you have any questions or want to get something on order, feel free to reach out to any one of us here at Lethal Performance!
Check it out here!
