- Mike
- Apr 21, 2023
- 19
- 137
- 203
- Brandon SD
- 2023 Ford Bronco
- Badlands
I picked up a set of WT SAS strut/spring assembly and tires from a 21 WT SAS that was pulled right away to upgrade to larger tires and lift. I have read many threads and if I stay with non SAS I will run the possibility of rubbing of inner fender with keeping the stock non SAS vs SAS. Wife loves the ride of the Bronco compared to the Jeep so not wanting to sacrifice the ride quality. BL non SAS has more travel than the SAS so is the only thing I am losing is the articulation but what am I gaining by putting on the SAS WT assembly other than .43 lift. I would think a 1/2 spacer can make that up with out the extra work. of complete removal of assembly(might be wrong). Both from a 4d, BL 2.3 WT 2.7 both auto so ride should be similar and with WT being a desert runner I am assuming a softer spring rate which would probably negate the weight of the 2.7 vs 2.3 difference. Want to tackle this weekend and deciding which way to go. Also if changing assemblies I am assuming to tell alignment shop to align for a SAS BL? Thanks for the input
