- Eric
- Jul 10, 2021
- 37
- 1,267
- 4,111
- Sacramento, California
- 2017 Raptor
- Wildtrak
JB4 Tuner for 2021-Present Ford Bronco & Bronco Raptor Up To 100hp & 120tq Gain
Price $450.00 +shipping.
I purchase the tuner Feb of 2022. Never used it at my age more into rock crawling than speed. All components still in original packaging. ebay would not let me list this in my store "This item can't be listed on eBay because it could be used to defeat, bypass or shut down the emissions controls in a motor vehicle. This includes tuners, regardless of functionality, or items described as off-road" only or racing only."
Comes with the wireless connect with is an add on. Suggested retail is $ 678.00
Wirelessly connect the JB4 for the Ford Bronco to your Bluetooth 4.0 compatible iOS and Android device via the JB4 Mobile connect kit, or to your Windows laptop with the BMS data cable. Both options allow you to record and analyze vehicle and tuning data, change JB4 performance maps, and update JB4 firmware as we release free newer versions with updates, more powerful maps, and new features under development. Separate JB4 Mobile app purchase also required.
USPS Ground Advantage 2 - 5 business days $8.85 - $17.65 depending on zip code.
Will send invoice via paypal.
Information from the Burger Tuning website.
Power gains of up to 100hp and 120tq to the wheels on a stock Bronco without the risks of flashing!
This plug and play tuner attaches to two easy to access sensors in the engine bay and works with your factory ECU tuning to remap your boost, timing, and fueling for optimal performance and reduced turbo lag.
Installation is very discrete and unlike flash remaps which are quick to install but can never be fully removed with a JB4 the vehicle is never aware it's making more than the factory boost or power levels. Fuel economy during normal driving is unchanged and it's compatible with all driving modes including towing. The JB4 is able to auto detect engine size and adjust tuning accordingly making it compatible both the 2.3t and 2.7t models.
Unlike other less advanced systems, the JB4 includes CANbus functionality allowing it to take in critical engine data directly from the ECU for real-time tuning. The data includes pedal position, throttle position, timing advance, fuel trims, air/fuel ratio, engine knock, fuel trims, gear, and much more. Other tuners without CANbus are not able to even monitor this critical engine data no less incorporate it real-time into their tuning algorithms. CANbus allows the JB4 to provide huge power increases with unparalleled power delivery.
The JB4 includes multiple maps including those for 91 octane, 93 octane, factory tuning, E85 mixtures, and unleaded race gas. In addition, it offers boost by gear settings to improve launches, the ability to read and delete fault codes, and much more. The JB4 is made in the USA and includes a 5-year warranty.
JB4 Map Guide:
Map0: Fully disable JB4
Map1: +3.5psi peak over stock, default map, 91+ octane
Map2: +3.5psi peak, less top end taper, more aggressive version of map1.
Map3: +4psi peak, suggested for 93+ octane and/or modified trucks
Map4: +6psi peak, suggested for 30% E85 mixtures
Map5: +7psi peak, suggested for 30% E85 mixtures and/or unleaded race fuel
Map6: Custom tuning map user adjustable
Map7: WMI (water/meth injection) progressive tuning
JB4 Map Guide:
