KMC 550 riot SBL anthracite Fitment
Paulj826
Nissan
Anyone know if KMC 550s will fit a 23 badlands 4 door non sas. 35 inch tires .? 17X8.5 KMC WHEELS KM550 RIOT SIMULATED BEADLOCK ANTHRACITE WITH SATIN BLACK LIP 6X139.7 (6X5.5) 10MM
Raptor911
Raptor911
Broadlands, VA
Yes! The wheel will fit with no issues. What tire size are you running? If you are running 35s then you will most likely need at least 1.5 inch lift.
BTW .. this is the Raptor section.
Paulj826
Nissan
315/70r/17
Raptor911
Raptor911
Broadlands, VA
315/70/17 are 35s so you may need a lift
BTW ... the wheels above are not hub centric for the bronco so you may want some hub-centric rings. You don't have to BUT it is a good idea for your wheels to be hub-centric.
315/70r/17
Paulj826
Nissan
Thanks good point and for the advice. I would need 106.1 to 93.1 hub rings. I have heard plastic rings are the way to go. Any opinion there?
88to21bronco
Tennessee
2017 Nissan Titan XD
I have run plastic rings and had good luck with them. And I agree with the previous poster…though not required, I have run with and without rings and rings on non-hub-centric wheels make a huge difference in ride quality at moderate speeds.
vrtical
Doug
GSMNP, TN
Fords
do not use plastic rings if you plan to off road at all. They work perfectly fine a street cars.
Paulj826
Nissan
Got it , thanks.
