- John
- Sep 3, 2021
- 24
- 2,408
- 2,259
- Pennsylania
- X4
- Outer Banks
Have you seen this article floating around the web and are you worried that the wheels on your Bronco are going to BURST or the tires CRACKLE that you place an empty water bottle when you park? Well I just so happen to have shares in a little bridge down in Brooklyn I would be willing to sell.
OTOH, if Broncos are prone to wheels bursting and tires crackling (and bursting while parked) maybe class action is warranted
42. Put A Plastic Bottle On Your Tires When Parked
Have you ever seen a parked vehicle with a plastic bottle on the tire? No? Well keep reading because the answer may surprise you in what a simple plastic bottle can do for your wheels. The biggest reason why you should put a plastic bottle on your tire is to avoid the wheel from jamming. Trailers use this method. The plastic bottles help drivers to see if the wheel starts to burst. And since the trailer is so long, they cannot see this unless the plastic bottle can be a sign. Another cool use for the plastic bottle is that in cold weather, bolts can freezeā¦ the plastic bottle can help so that the tire will not crackle or burst.
It is important to note that if you happen to find a plastic bottle on your tire that you did not place yourself, you need to exercise caution. It has been reported that it is a tactic thieves use to distract the driver as he starts to move the car. The plastic bottle will make a loud crunching noise which will cause the driver to get out of the car to check. Once the driver is out of the car, the thief will try to enter the vehicle and steal the car or other valuables.
