Liqui Moly and UPR Oil Change Necessities! | Lethal Performance
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Hey All!
As we get close here to changing the oil in our very own 2021 First Edition 2.7L, we researched to ensure we got the best products for our vehicle, and of course, with the add-ons that make future oil changes less of a hassle.
Check out the video here! :
To start, our friends at Liqui Moly hooked us up with the perfect combo for our Bronco.
Before we change the oil in our Bronco, we will be adding the Liqui Moly Engine Flush, as instructed, to clean out any possibly build-ups or deposits. While this is more intended for use on higher mileage motors, it's never a bad idea to start preventing build ups from getting bigger than they need to be. LIQUI MOLY Pro-Line Engine Flush - 0.5 Liter - 2037 (LQM-2037)LIQUI MOLY Pro-Line Engine Flush
Once we pull the drain plug and drain the oil, we won't be using that old drain plug, but instead, we will be using the UPR Billet Drain Plug instead. This little additions is the cherry on top and will make the oil change on the next round even easier, as well as pick up any metal debris floating around in the oil with it's magnetic tip. UPR 3025-01 Products Billet Drain Plug with Magnetic Tip (Mustang GT / GT350 / F150 / Explorer ST / Bronco) (UPR-3025-01)
Not only are we just changing the oil with their Special Tec AA 5W-30 Synthetic, we will be adding their Cera Tec to it to give it even another layer of protection, while it also coats and polishes any imperfections in cylinder walls, as well as ensures a little metal-to-metal friction as possible.
LIQUI MOLY Special Tec AA 5W-30 - 5 Liter - 20138 (LQM-20138)LIQUI MOLY Special Tec AA 5W-30
LIQUI MOLY CeraTec - 0.3 Liter - 20002 (LQM-20002)LIQUI MOLY Cera Tec - 0.3 Liter
Check out the entire oil change kits listed here, for both 2.3L and 2.7L :
https://www.lethalperformance.com/s...r/ford-2021-bronco/fluids/oil-change-packages
As always, if you have any questions, concerns, or want to get one on order, shoot us a call at 561-753-8105 or shoot us an email at [email protected]!
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
