The velcro tape is positioned where the blue lines are. It needs to be moved out to the red lines in order to touch the carpet.The position of the blue circle should be fixed, right?
魔术贴胶带位于蓝线所在的位置。它需要移到红线才能接触地毯。
Also, that hole is a little off centered on my pair.The velcro tape is positioned where the blue lines are. It needs to be moved out to the red lines in order to touch the carpet.
Thank youThe velcro tape is positioned where the blue lines are. It needs to be moved out to the red lines in order to touch the carpet.
a little bit more room on the bottom where it goes between the hingesAlso, that hole is a little off centered on my pair.
And I agree on a little bit more room on the bottom where it goes between the hinges.
Ironic. That's one of the reasons I like that cubby. I ordered it and installed it temporarily (without using the 3m tape). Thought it might bother me. I actually use it as a sort of leg 'rest' during longer drives. I'm a decent sized person at 6'3" 230lbs and have large legs / calves.Picked one of these up from your Amazon store but won't be able to use it. On the drivers side it contacts my calf when using the gas pedal. 6 or 7 mm narrower it may have missed it, but where it is I would start to have pain on a long drive with it located there. I'm sure it won't be a problem for others, but I tend to have larger calves due to my weight lifting and running.
No. They are independent thoughts about two different issues.a little bit more room on the bottom where it goes between the hinges
Do these two sentences mean the same thing?
Thank you, Your answer helped me a lot, I will checkNo. They are independent thoughts about two different issues.
The comment about the bottom is a reply to an earlier post. I think it's a size issue with the overall mold. But, it is not critical.
The critical aspect is that the velcro tape does not adhere to the backing carpet because it is not placed far enough out from the hole.
不,它们是关于两个不同问题的独立想法。
关于底部的评论是对之前帖子的回复。我认为这是整体模具的尺寸问题。但是,这并不重要。
关键方面是魔术贴胶带不会粘在背衬上,因为它距离孔的位置不够远。
I'm going to use a heat gun on it and see if I can push it back a bit and see if it will stay. It needs just about 6 mm. The average calf size for a guy is no higher than about 40 cm, but for me, I'm about 45cm.Ironic. That's one of the reasons I like that cubby. I ordered it and installed it temporarily (without using the 3m tape). Thought it might bother me. I actually use it as a sort of leg 'rest' during longer drives. I'm a decent sized person at 6'3" 230lbs and have large legs / calves.
No the bottom of the cover that is nearest to the floor of the car. The seats have hinges and the cover is touching them and it needs to have a bit of material removed so it’s not colliding with them so much. I posted a picture of the area the green lines are where I’m talking abouta little bit more room on the bottom where it goes between the hinges
OK, i knowNo the bottom of the cover that is nearest to the floor of the car. The seats have hinges and the cover is touching them and it needs to have a bit of material removed so it’s not colliding with them so much. I posted a picture of the area the green lines are where I’m talking about
Not much but it’s just enough to get bound up with the hinges
Any update on the Mabett mudflaps?OK, i know
