- Nick
- Jul 17, 2020
- 22
- 236
- 528
- Houston
- Website
- www.apollo-optics.com
- 2022 Wildtrak | 2021 GT500 | 2019 F-250
- Wildtrak
If you've been looking to upgrade the headlights on your Bronco, we've got options in stock from Morimoto for you right here at Apollo Optics!
There are two main types of headlights available from Morimoto - the XRGB and the XB headlights.
Let's break down the differences between these two options:
Morimoto XRGB
Click Here for full product listing: https://apollo-optics.com/xrgb-led-headlights-ford-bronco-21-pair-rgb-drl-lf496/
The XRGB is going to have more of an OEM+ look compared to the the XB headlights. The XRGB uses a similar style DRL halo to the factory Signature LED headlights, however, the DRL color is adjustable via Bluetooth for various different colors. Just make sure you check our local laws on which colors can be run on the road in your area.
The actual low beam and high beams themselves are a big upgrade over the stock LED reflectors and are replaced with Morimoto's LED projectors. Providing add brightness, wider pattern, and whiter light than the stock heads.
Low Beam Output:
High Beam Output:
Morimoto XB
White DRL: https://apollo-optics.com/xb-led-headlights-ford-bronco-21-pair-white-drl-lf497/
Amber DRL: https://apollo-optics.com/xb-led-headlights-ford-bronco-21-pair-amber-drl-lf497-a/
Now the next option is the XB headlight. This ditches the OEM+ look for a uniquely custom look. Instead of dual projectors, it uses one single bi-LED projector in the middle and is available in either a white DRL or an amber DRL.
White DRL:
Amber DRL:
And while the actual headlight went from dual projectors in the XRGB to a single bi-LED projector in the XB, the light output is still very impressive over stock.
Low Beam:
High Beam:
We have the XRGB and XB White DRL headlights in stock and ready to ship immediately. The XB Amber DRL is about 3 weeks out at this point.
If you have any questions or would like a quote, feel free to message me and I'll be happy to help!
Morimoto XRGB
Low Beam Output:
High Beam Output:
Morimoto XB
White DRL:
Amber DRL:
Low Beam:
High Beam:
