New Bronco Owner can you remove the hardtop front /rear if it has a factory installed roof rack ?
Bosco24
24 Outer Banks
I hope so. 🫣
denverbronco2023
Travis
'09 A4 Avant (BT, 350whp), '18 Mazda CX9, Bronc
Only front panels, rack needs to be off for middle (4 door only) and back.
Bosco24
24 Outer Banks
Thanks that should work for me 🙏
BearPatrol
23 Bronco
I do it all the time.
fpostgate
Farley
Syracuse, NY 13219
Ford Bronco 2024
Wait, you have to take the roof rack off right?
I was trying to see if I could get my front sections removed today, but it seemed like too much interference to slide the sections out.
TrailRaider
Mr. G
So. Cal
Focus ST, Mitsubishi Montero, Bronco Badlands
C6ZZGT
Seattle
66 GT Mustang,94 Escort wagon,
Front sections can come out BUT it is finicky and you have to wiggle them just right to do it. Going back on is the same.
Middle needs rack off .
fpostgate
Farley
Syracuse, NY 13219
Ford Bronco 2024
So do you try to slide them out the sides then or up through the middle?
RedDawg
Erik
Chrysler
Slide them out the sides.
Unlatch, lift up, wiggle back (just a bit), pull them out from the sides.
I have it down pat. It takes me longer to put them in the bag than to take on and off.
Murraydog11
Rick
NJ
2021 2Dr Outer Banks, Jeep Cherokee
The key is close the front latches before sliding them out.
Hard head
Louisville KY
2023 Bronco
I tried mine the other day. They come off, just takes a little finesse. I had to slide it back, on top of the middle section just a bit. And close the front hold down clamp
fpostgate
Farley
Syracuse, NY 13219
Ford Bronco 2024
Yup I did get them out, I didn't know if they were supposed to be able to be removed with the rack on, once I knew, a little pushing was no big deal. It took a little messing with the angle of the dangle, but I got it, Thanks!
