I click on the link and go to the Canadian Amazon site, so I go to the US site and find nothing?
I also can't find this on the Mabbet site...
A compressor has a place to store the compressed air. All inflators create pressure, thereby compressing the air. It's arbitrary semantics, really.Ok i guess, not really sure
ok i guess…. Not sure
how a tank changes the operation of a pump vs a compressor
But from 10 to 35 psi, you'll be waiting over 10 minutes. Just be careful how long the unit runs, as you can see above the wiring gets quite hot!So my wife got me one for valentines day. She thought it would be nice for airing up the Kayaks. It took me 3 hours to install. I had to remove my subwoofer box to run the wires. The power and the ground wire terminators on the unit broke off as I tried to install them. It took forever to get it lined up and in the tailgate. It's a tight squeeze. To test it I level out all the tires on the Bronco. It took about 1 minutes a tire to get from 35psi to 39 psi.
So is it a compressor or more like a air pump style? In other words, does it look more like an ARB or VIAIR single compressor, or more like thhose electric air pumps?So my wife got me one for valentines day. She thought it would be nice for airing up the Kayaks. It took me 3 hours to install. I had to remove my subwoofer box to run the wires. The power and the ground wire terminators on the unit broke off as I tried to install them. It took forever to get it lined up and in the tailgate. It's a tight squeeze. To test it I level out all the tires on the Bronco. It took about 1 minutes a tire to get from 35psi to 39 psi.
Given that its fully inclosed I can't say but I am thinking air pumpSo is it a compressor or more like a air pump style? In other words, does it look more like an ARB or VIAIR single compressor, or more like thhose electric air pumps?
do ya know what kinda Amps under load it pulls, just curious
14 and change is what I saw during testing when the wires were screaming hot.do ya know what kinda Amps under load it pulls, just curious
only like 170 W, so figure two 100 W light bulbs there.. if the wires were HOT maybe go up a size or two?14 and change is what I saw during testing when the wires were screaming hot.
I wouldn't touch the thing it it were my rig. Many better options out there.only like 170 W, so figure two 100 W light bulbs there.. if the wires were HOT maybe go up a size or two?
yupI wouldn't touch the thing it it were my rig. Many better options out there.
