- Mark
- Mar 4, 2021
- 8
- 105
- 240
- Pennsylvania
- 2013 f-150 FX4
- Wildtrak
Thanks brother. Don't know how I missed this thread.
Wow my connection was so short on the C1R that the pigtail stuck out of the bracket to get it to connect to the factory harness. On the BRaptor the exhaust is on the drivers side so I opted not to use the product. Wish I could!
Is anyone else having the hitch mount fooling the bronco into thinking there is a trailer attached? This is on a factory 7 pin connection.![]()
I installed it. Was close to the exhaust so wrapped it. Take a look at the link.just called them and they said they had a Warthog in the shop and it worked fine.
https://www.bronco6g.com/forum/thre...hmount-led-pod-reverse-kit.57663/post-1803849
Great video review from our friends at Quadatec of our C1 and C1R Hitch Mount LED Pod Reverse Light Kit!
when will you have the version that is rewired for Ford vehicles that will tell the vehicle you are not towing and thus leave cross traffic alert on?
I've got a C1R on my Wildtrak with the factory tow package and I don't get any warnings or lack of function.
Everything seems to be working as intended
I called them 2 weeks ago and was told NOT to buy one as a Ford application is coming out soon.
Apparently when you install one on a Ford, the vehicle thinks you are towing and disable cross traffic alert.
Try this, put an object behind your wildtrak and then put it in reverse and back up .. I think the rear sensors are turned off and will allow you to get closer to the object without warning.
All of my sensors are functioning as intended. I've had it installed for 2wks or so with plenty of parallel parking, backing out of driveways etc. I get all the notifications/warnings as I did before the install- cross traffic, proximity etc
