Just trying to find out if they will fit. They came on my Black Diamond.
I'm confused what your trying to say. What you trying to do. Do you have the beadlock capable Sasquatxh rim?Just trying to find out if they will fit. They came on my Black Diamond.
I'm trying to find out if the rims I have are "bead lock capable." Can I put OEM Bead Lock Rings on the wheels that came with my BD Bronco?
Pictures of what? When you go to the Ford Parts site they have a couple of Bead Lock options, depending upon the wheel to which it will be attached, but their wheel descriptions are confusing. Based on the description I can't tell if my wheels are eligible or what they call Bead Lock capable. I'm asking if someone on the forum with experience in regard to OEM wheel options can tell me whether my wheels are compatible with the items available on the Ford Parts site.
The standard black wheels won’t work. They must be beadlock capable, meaning they come with beauty rings installed. Looking at the photos of the Black Diamond wheel options from the Build & Price tool on the Ford website (see below), only the wheel on the right will work.Can you tell whether a wheel can take a Bead Lock ring by appearance? If yes, what feature on the wheel would I look for? In the meantime, I'll try to get a pic posted.
You’re welcome. See the following post for more info…Well thank you for checking it out. My wheels did not come with trim rings. Also, they are painted aluminum, not steel. I'm guessing that the wheels with trim rings also have tapped holes for the ring bolts. My wheels definitely do not have any tapped holes.
