Opinion on drivability?
Function_7
James
'Berta
Just my Bronco
Hypothetically, if someone managed to crossthread the 2 nuts for the 18mm bolts on the diff mount at the front of the vehicle, and couldn’t get the bolts back in, would it be ok to drive around temporarily until the right tools arrived to fix the issue?
Asking for a friend.:facepalm:
bassist
Northern VA
2024 Bronco Badlands w/Sasquatch Package
Have you considered faking your own death and moving to another state as a possible option?
You won’t have the problem with the cross threaded bolts anymore.
Function_7
Function_7
James
'Berta
Just my Bronco
Yikes, is it that bad?
gonna be tough to fake my death and move if I can’t drive
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
Do you own a welder? (JK, don't do that) Remember, mounting bolts have a 3 ugga dugga torque spec, not 5.
Function_7
Function_7
James
'Berta
Just my Bronco
Too strong for my own good I guess...must be old man strength
Coosguy
Phil
New Hampshire USA
Bronco outerbanks
Retap the holes , and see if they will hold the torque. Look up the torque spec on a chart that you can google and use a torque wrench, If the threads are so bad that they cannot be just touched up you will have to install a heli-coil .
Function_7
Function_7
James
'Berta
Just my Bronco
That's the plan, hopefully tapping works. I don't think I pushed things too far, so I don't think it's too bad. (Famous last words)
bassist
Northern VA
Seems a lot harder than faking one’s death.
