- Mitch
- Apr 7, 2021
- 91
- 291
- 998
- St. Louis, MO
- Website
- www.pandamotorworks.com
- 2021 Ford Bronco, 2014 Fiesta ST
- Outer Banks
Looking for the best fog light pocket kit for your Ford Bronco? Look no further, the Panda Motorworks x Diode Dynamics Fog Light Pocket Kit is here! We listened to our customers feedback, and came up with the Ultimate Diode Dynamics Fog Light kit! This kit offers a huge lighting and aesthetic upgrade, while also being easy to use and install!
Features
Backlight Functionality. Each pod in this kit includes a distinctive Amber backlight feature that can be controlled separately using the factory aux switches. The backlight on each pod included with the kit fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
Sport, Pro, or Max. This kit is available at three different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The Sport model uses high-intensity LEDs, and is the best bang for the buck you’ll find. The Pro model steps things up in a big way, with double the total power. Finally, the Max model features our SS3 Max LED pods, which have been designed with cutting-edge automotive emitters for both high power and extreme intensity. This brand new technology comes at a cost, but if you’re looking for the absolute best in lighting performance, the SS3 Max is the answer
Simple connections. All Stage Series LED pods feature a custom-molded DT type Deutsch-style connector on the back For installation, you can wire yourself, use an off-the-shelf Deutsch DT sized wire harness, or select an optional Diode Dynamics wire harness.
Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
This kit includes:
AUX Switches
No AUX Switches
Email [email protected] for custom configurations!
Features
- Bolt-on fitment for 2021+ Ford Bronco with steel bumper.
- Adds SAE-compliant fog lights, and powerful offroad lighting.
- Harnesses included for independent control of road-legal and offroad lighting.
- Backlight feature provides amber accent light.
- Highly durable powdercoated stainless steel bracket
- SS3 SAE Fog provides an extremely wide field of view, with high-intensity output over an entire 80-degree spread. It will fully illuminate the area in front of your vehicle.
- SSC2 Combo pattern combines both the Driving and Flood optics, and provides maximum visibility. It shines light downrange in a focused, rectangular 40x20 degree pattern. The combo lens features a flood optic on one side and a driving optic on the other.
- SAE Driving is designed to supplement your high beams, but it’s great for general illumination as well. Rather than a traditional "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to fully illuminate the road ahead at high speeds.
This kit includes:
AUX Switches
- 2x Diode Dynamics SS3 SAE Fog Light Pods (White or Yellow)
- 2x Diode Dynamics SSC2 Combo Pods
- 2x Diode Dynamics SSC2 Driving Pods
- 1x KR Offroad Triple Fog Flush Bezel Bracket
- 1x CrystaLux Triple Fog Light Harness
No AUX Switches
- 2 x Diode Dynamics Standard Duty Harness
- 2 x Diode Dynamics Splitters
