Diode Dynamics Triple Fog Light Kit w/KR Off-Road Flush Mount Brackets
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Give that Bronco some much needed lighting with this Triple Fog Light Kit for the 2021+ Ford Bronco. We pair our KR Off-Road Triple Fog Light Brackets with your choice of three pairs of Diode Dynamics lights, for the ultimate fog light setup.
The KR Off-Road brackets are made out of 12 gauge stainless steel and are powder coated black. The bezel style/flush mount design gives that fog opening a finished look while giving you adjustability in where the lights aim.
Included are the following:
  • 1 Pair of KR Off-Road Triple Fog Light Brackets
  • 3 Pairs of Diode Dynamics Lights
  • Upfitter Wiring Harness (If you don't have upfitters we recommend an auxiliary switch panel)
  • Instructions
  • Our Lifetime Guarantee. For as long as you own your Bronco, if you manage to break/bend/destroy the KR Off-Road brackets we'll replace them free of charge (not including return shipping)
SS3 Backlit Upgrade: The SSC2 features an amber back-light (which is turned on from a separate switch). The SS3 are also available with this feature for a $40 upcharge. The included wiring harness has a 4th backlight control wire which you can wire to a 4th upfitter switch in your vehicle.
Ford Bronco Diode Dynamics Triple Fog Light Kit w/KR Off-Road Flush Mount Brackets moved-c069bf4be95f9d5d7553435153c3d75e
Order Here: https://www.4x4truckleds.com/diode-...ckets-for-2021-ford-bronco-hd-modular-bumper/
Use coupon code BRONCO6G and save 10% on your kit!
We have made some recommended choices to help you out if you need a bit of assistance picking which lights to go with:
RECOMMENDATION #1 (Good Street Legal Setup)
  • SS3 Sport, White SAE Fog
  • SSC2 Sport, White Combo
  • SSC2 Sport, White Spot
SS3 Sport SAE Fog lights will give you a street legal output. These would act as your normal fog lights, which you can leave on all the time.
SSC2 Sport, Combo is equipped with both a wide/fog pattern and a spot pattern which provides a nice blend of light for both near field applications and distance lighting.
SSC2 Sport, Spot is a longer/narrower beam that focuses the light down the trail or road.
RECOMMENDATION #2 (Better Street Legal Setup)
  • SS3 Pro, White SAE Fog
  • SSC2 Pro, White Combo
  • SSC2 Pro, White Spot
The patterns in this setup are identical to Recommendation #1, however we're upgrading the lights from a Sport output to a Pro output, giving you more light.
RECOMMENDATION #3 (Best Street Legal Setup w/Most Output)
  • SS3 Max, White SAE Fog
This is similar to the setups above, but we're changing a few options.Going with the Max on the SS3 increases the output yet again.
SS3 Max SAE Fog lights will give you a street legal output. These would act as your normal fog lights, which you can leave on all the time.
SSC2 Pro, Combo is equipped with both a wide/fog pattern and a spot pattern which provides a nice blend of light for both near field applications and distance lighting.
SSC2 Pro, Spot is a longer/narrower beam that focuses the light down the trail or road.
RECOMMENDATION #4 (OUR Recommendation)
  • SS3 Max, White Combo
  • SSC2 Pro, White SAE Fog
  • SSC2 Pro, Yellow SAE Fog
This is our recommended setup. The combo light is a great light to light up everything as it consists of a driving and a flood pattern. Then we're going with fogs in white and yellow for that street legal use. One set of fogs in white is good for normal clear driving conditions while the 2nd set in yellow is better for bad weather (snow, rain, fog). If you want to save some money you can opt for the SS3 in Sport or Pro to save some money, but we do recommend the SSC2 stick with a Pro pattern to give you the most light output in that smaller footprint. Please note, on the SSC2 fogs, you will need to flip the bezel/lens around 180 degrees so that they sit right-side up. When doing this, there are 2 small indexing plastic tabs on the back of the lens you need to just trim off (these are used during production to aid in installation but you can simply trim them off with a knife).
Ford Bronco Diode Dynamics Triple Fog Light Kit w/KR Off-Road Flush Mount Brackets New-XB-6
Ford Bronco Diode Dynamics Triple Fog Light Kit w/KR Off-Road Flush Mount Brackets 312436232_646103617243820_1944840356797014517_n
Ford Bronco Diode Dynamics Triple Fog Light Kit w/KR Off-Road Flush Mount Brackets 307014345_2258893057785463_2298286029693674664_n
Ford Bronco Diode Dynamics Triple Fog Light Kit w/KR Off-Road Flush Mount Brackets 306731980_565001195381109_7640352145486352053_n
Ford Bronco Diode Dynamics Triple Fog Light Kit w/KR Off-Road Flush Mount Brackets 305314209_453089553426603_6696321984085617219_n
Ford Bronco Diode Dynamics Triple Fog Light Kit w/KR Off-Road Flush Mount Brackets 305494940_785290932814798_7706983248020549158_n
Ford Bronco Diode Dynamics Triple Fog Light Kit w/KR Off-Road Flush Mount Brackets Photo Jul 26 2023, 2 06 42 PM
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Our flush mount brackets are one of our most popular sellers. Post a photo up of your truck rocking our fogs. PLENTY IN STOCK!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Our BLACK FRIDAY Sales event is happening RIGHT NOW. Visit our Black Friday page for the complete list of sales: https://www.4x4truckleds.com/bf-2023
Our Fog Kits are currently 15% off
Ford Bronco Diode Dynamics Triple Fog Light Kit w/KR Off-Road Flush Mount Brackets BOX-Bronco & Raptor Fog Light Kits copy
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Our brackets are BACK IN STOCK!
