- Adam
- Aug 30, 2021
- 355
- 4,383
- 5,848
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
Give that Bronco some much needed lighting with this Triple Fog Light Kit for the 2021+ Ford Bronco. We pair our KR Off-Road Triple Fog Light Brackets with your choice of three pairs of Diode Dynamics lights, for the ultimate fog light setup.
The KR Off-Road brackets are made out of 12 gauge stainless steel right here on Long Island (New York). Powder coated black to ensure a durable finish, these heavy-duty brackets feature multiple mounting positions ensuring your brackets not only stay on the truck, but offer you adjust-ability as well. You'll be able to rotate the lights left, right, up & down allowing you to focus the light precisely where you need it. On top of that, the lights sit in a channel which allows you to slide the light left or right.
Included are the following:
Order Here: https://www.4x4truckleds.com/diode-...ckets-for-2021-ford-bronco-hd-modular-bumper/
Use coupon code BRONCO6G and you'll save 10% on your kit!
We have made some recommended choices to help you out as far as light selection goes:
RECOMMENDATION #1 (Good Street Legal Setup)
RECOMMENDATION #2 (Better Street Legal Setup)
The SSC2 White in the SAE Fog pattern is a street legal light. This will act as your primary fog light. The 2nd SSC2 in Yellow is another street legal fog light but yellow is best suited for poor weather (dust, snow, rain, etc...) Having two pairs (one in white, one in yellow) is ideal as you can select which pair of lights depending on the weather. The SSC3 Combo light combine a driving and flood optic into one light. This shines downrange in a focused rectangular pattern.
RECOMMENDATION #3 (Best Street Legal Setup w/Most Output)
The SSC2 White in the SAE Fog pattern is a street legal light. This will act as your primary fog light. Unlike recommendations #1 and #2 we're changing the yellow SAE Fog to a larger SS3 light for the most output. The SS3 Max SAE Fog in Yellow is another street legal fog light but yellow is best suited for poor weather (dust, snow, rain, etc...) Having two pairs of SAE lights (one in white, one in yellow) is ideal as you can select which pair of lights depending on the weather. The SSC3 Combo light combine a driving and flood optic into one light. This shines downrange in a focused rectangular pattern.
- 1 Pair of KR Off-Road Triple Fog Light Brackets
- 3 Pairs of Diode Dynamics Lights
- Upfitter Wiring Harness (If you don't have upfitters we recommend an auxiliary switch panel)
- Instructions
- Our Lifetime Guarantee. For as long as you own your Bronco, if you manage to break/bend/destroy the KR Off-Road brackets we'll replace them free of charge (not including return shipping)
- SS3 Sport, White Combo
- SSC2 Sport, Yellow SAE Fog
- SSC2 Sport, White SAE Fog
- SS3 Pro, White Combo
- SSC2 Pro, Yellow SAE Fog
- SSC2 Pro, White SAE Fog
- SS3 Max, White Combo
- SS3 Max, Yellow SAE Fog
