- Adam
- Aug 30, 2021
- 355
- 4,383
- 5,846
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
Give that Bronco some much needed lighting with this Triple Fog Light Kit for the 2021+ Ford Bronco. We pair our KR Off-Road Triple Fog Light Brackets with your choice of three pairs of Baja Designs lights, for the ultimate fog light setup.
The KR Off-Road brackets are made out of 12 gauge stainless steel and are powder coated black. The bezel style/flush mount design gives that fog opening a finished look while giving you adjustability in where the lights aim.
https://www.4x4truckleds.com/baja-d...ckets-for-2021-ford-bronco-hd-modular-bumper/
Use coupon code BRONCO6G and save 10%
Included are the following:
RECOMMENDATION #1 (Street Legal Setup)
S2 Sport, Driving/Combo is equipped with both a wide cornering and spot pattern which provides a nice blend of light for both near field applications and distance lighting.
S2 Sport, Spot is a longer and narrower beam that focuses the light down the trail or road.
RECOMMENDATION #2 (Best Street Legal Setup)
Squadron SAE Wide Cornering lights will give you a street legal output. These would act as your normal fog lights, which you can leave on all the time.
S2 Sport, Spot is a longer/narrower beam that focuses the light down the trail or road.
RECOMMENDATION #3 (Off-Road Use)
S2 Sport, Wide Cornering is designed for cornering/dust/fog conditions. While technically not street legal this is a light that can be used for fog light applications where applicable.
RECOMMENDATION #4 (Best Off-Road Use)
The Squadron Pro, Spot light provides a longer/narrower beam that focuses light down the trail or road.
S2 Pro, Driving/Combo is equipped with both a wide cornering and spot pattern which provides a nice blend of light for both near field applications and distance lighting.
S2 Pro, Wide Cornering is designed for cornering/dust/fog conditions. While technically not street legal this is a light that can be used for fog light applications where applicable.
RECOMMENDATION #5 (*STAFF PICK*)
Order Here: https://www.4x4truckleds.com/baja-d...ckets-for-2021-ford-bronco-hd-modular-bumper/
- 1 Pair of KR Off-Road Triple Fog Light Brackets
- 3 Pairs of Baja Designs Lights
- Wiring Harness
- Instructions
- Our Lifetime Guarantee. For as long as you own your Bronco, if you manage to break/bend/destroy the KR Off-Road brackets we'll replace them free of charge (not including return shipping)
- Squadron SAE, Wide Cornering
- S2 Sport, Driving/Combo
- S2 Sport, Spot
- S2 Pro, Driving/Combo
- S2 Pro, Spot
- Squadorn Sport, Spot
- S2 Sport, Wide Cornering
- Squadorn Pro, Spot
- S2 Pro, Wide Cornering
- Squadorn Pro, Driving/Combo
- S2 SAE, Wide Cornering
- S2 SAE, Wide Cornering Amber
