Incognito
Incognito
Phoenix
2017 jk
what are the width of your jeep 35" wheels? The SAS 17x8.5"; like to know this for comparrison purposes.
Kenda RT 601 in 35x10.50R17.
D Rated too.
Kenda made them specifically targeting the Jeep market and hit a home run.
Very highly rated on the Jeep forums.
I love them and will probably replace the GY Territorys instantly with them.
If Granger will roll it into the loan.
lowmpg
Ryan
Maryland
F350
Outstanding job. Now I have to add CG to a possible color......
Milamdj
Nashville, TN
Nissan Versa
Went over to the Bronco sleeping grounds in Phoenix today.
Drove in my Wrangler running on 35"s and a 2" lift.
The Wrangler and the Sasquatched 4D Cactus Grey Bronco are almost exactly the same hight.
Cactus grey is indeed US Military Fighter Jet Grey.
It has an extremely light green tint that cameras love to emphasize.
US Airforce airman ( B6G lurker) there at the same time commented that it's Military Grey with a gloss coat.
These pictures came out right.
More pics of the Cactus Grey that came out too green.
Also, those GY Territory tires hold rocks like they were gold nuggets.
I counted 8 rocks stuck in the front driver's side. quit counting after that.
Those tires are getting replaced.
Finally on the Sasquatch.
Ford really pushed the DOT fender coverage envelope.
Not much point in getting smaller flairs unless you want to beat the paint up on the side of you Bronco.
On to Cyber Orange:
The CO should have been called Early Bronco Chrome Yellow metallic.
This was the only non-frankenbuild there at the time.
It looked to be about the most prodution accurate of the Broncos there.
CO looks great, but I'm glad I saw it in person, because it's off my list.
Overall a really nice color that shows off the Bronco's lines.
The MIC top is beautiful on this.
last and least was the beat up black OBX with the hideous prototype top.
It has the Bronze dash.
That looks *good*!!
Same cactus grey bronco we saw posted in PA a couple months ago. Still pretty. Thanks for sharing the info and photos.
Ksjrb03
Tx
F250
Thanks for measuring the tires. Shows why the overland squatch has less fender clearance. Real 35s will be stuffed.
Bvbronco
Bob
Prescott az
2019 jeep wrangler sport s
Nope .
Selling it when the Bronco comes in.
Funny thing, I special ordered it.
One of only about 20 at most that are Plum Crazy Purple with a 6M and 1/2 doors.
I just sold my JL and was Very Happy with the price a got for it . ? good luck with your sell
mrcx
Grapevine, TX
'67 Camaro
Since one of the first 2 pictures was taken a couple of feet closer than the other, I took the a vehicle from each and combined them to help offset the rear of the vehicles not being aligned. I added lines showing the width of the Bronco and those same lines on the Wrangler. Not perfect, but helps show the width comparison a little closer to what it actually is.
Ford Bronco Pictures: Sasquatch next to Jeep with 35" tires and lift & More Cactus Grey and Cyber Orange 1605571246816
Incognito
Incognito
Phoenix
2017 jk
315/70R17s are usually around 34" under load.
BFG 315s ( the Starbucks of offroad tires) are as small as 33.5".
I plan on getting a 2022 Mansquatch, adding a 1" body lift and pulling the Sasquatch .5" bigger than standard bump stops.
The 50%(?) aluminum Bronco body eliminates concerns about increasing the center of gravity.
And a puck lift is the cheapest thing going.
RedHotLava
Red
DC
2005 Nissan Xterra
[ATTACH type="full" alt="Cactus Gray Bronco Sasquatch 4-Door 2.jpg" said:
63158[/ATTACH]
This makes me rethink Cactus Gray and put it back in the running, from someone who's seen it in person.
Anyone else feel the same? I've always thought the computer generated coloring and the pics I've seen had some minty type green attached to it.
Incognito
Incognito
Phoenix
2017 jk
I should note that my Wrangler is a full 3" narrower than a stock Wrangler.
Fender width is 1.5" narrower per side.
buzpro
Binky
Tacoma
Ford Bronco Pictures: Sasquatch next to Jeep with 35" tires and lift & More Cactus Grey and Cyber Orange 1605572460929
what is that small piece on the rear window? between the hinges and to the right of the center brake light .... i see it on the orange bronco too but seems missing on the black
Incognito
Incognito
Phoenix
2017 jk
The window washer sprayer.
Even the Base has it.
The black OBX has it too, if you enlarge and enhance.
