Pinch weld covers!
Status
Not open for further replies.
5280Bronco
Denver
@JcrOffroad Are the pinch weld covers something you guys have stock of? Or do you make them as orders come in?
Snowdogyyz
23 Ford Bronco Wildtrak
Have these been confirmed to work with the Badlands rock rails?
5280Bronco
Denver
5280Bronco
Denver
@JcrOffroad I just wanted to verify that the pinch weld covers are included in the 5-20 business day lead time estimates you guys have on the site? Ordered last Thursday, and hadn't heard anything, but I was hoping they fall in the 5-20 days range and not some of the longer ones. Thanks!
JcrOffroad
JcrOffroad
Portage, Mi
2021 Ford Bronco Badlands
Yes. 5-20 range.
5280Bronco
Denver
Should I have any concern about rust if I just put the covers on over the now bare spots from the front screws? Thoughts anyone?
Ford Bronco Pinch weld covers! PXL_20220429_040708202
5280Bronco
Denver
Chelada
Bulverde, TX
2022 Bronco
I just did mine with this. It looks really good, so do the JCR ones as well.
I'm interested in this approach. Do you just apply painters top above and spray across? I assume you only have to worry about applying to the external side.
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
I just cleaned the surface. And then taped around the weld area to be sprayed. Remove the tape quickly after or the Wurth will bond with the tape. I did one coat. That Was enough. I just did the outside yes. Do some test sprays on a cardboard box first. Get the hang of the spray and coverage. You'll love it.
Status
