Put these on right away next morning after taking delivery, and getting a wicked rock chip on the way home. These as shown are set at 12" from ground, are very flexible, and have stainless fasteners. $45
Amazon shopping list
Flaps https://www.amazon.com/dp/B0002NIJS0?psc=1&ref=ppx_yo2ov_dt_b_product_details
6mm U-clips https://www.amazon.com/dp/B0B529J9H4?ref=ppx_yo2ov_dt_b_product_details&th=1
6mm screws https://www.amazon.com/dp/B0833W9T4F?psc=1&ref=ppx_yo2ov_dt_b_product_details
Step 1. Prepare the flaps for install, trace and cut included cardboard to match the flap shape to make a template.
Step 2. Mark hole locations on template at given measurements, drill 1/4" holes through flaps.
Step 3. Make 3 stand offs/spacers for mounting flaps 2 at 1/2" long, 1 at 3/4" long. I used 1/4" fuel line inside 1/2" pex tubing. Upper 2 locations use 1/2" long spacers, bottom one uses 3/4". Note you may want to paint them black, as they will show, bottom one for sure. Insert 6mm X 40mm screws.
Step 4. Installing u-clips. Remove bottom 2 plastic pins holding fiber fender liner in place, and attach u-clips to tabs in those locations. At bottom of fender well push liner behind an unused tab, and intall a 3rd u-clip in that location.
Step 5. Install flap. Screw flap to fender well/U-clips using the M6 x 40mm screws. Lastly (barely visable in photo below), locate the bump on the flare near the top of the flap, attach flap to that location using one of the provided self drilling screws which came with the flaps.
Step 6. Repeat on otherside.
Installed photos
Installed photos
