Problems Latching/Closing Hood
Mscdman
P
Denver
OBX
Ok dumb question. How are you supposed to
close the hood on the bronco? On my other cars, I’ve always lowered it and pressed down to latch it instead of dropping the hood and letting it fall to latch.
Pressing the hood doesn’t seem to latch it…
If I drop it from about a foot high it latches and closes. Is this how you are supposed to close the hood????
Lifeliberty
Moonbeam👀
Columbus, OH
That's how I do it. I have hood struts so i press down from about 6 inches, swift and smooth
The hood dont weigh much
Mscdman
P
Denver
OBX
I don’t have hood struts. Is there a problem if it won’t latch when pressing down? Right now, I have to drop it to latch. Is that bad?
Lifeliberty
Moonbeam👀
Columbus, OH
It's a Ford, you can slam it.(maybe not SLAM, Fords aren't made "Ford Tough" anymore) but force is needed
I don't think I've had a car where I didn't have to drop the hood
Unless something is not adjusted correctly like the latch or if the 2 round hood shims are too high.
I cannot lower my hood and then just press down to latch, needs some force
Mscdman
P
Denver
OBX
Thank you. This is my 1st ford so wanted to see if others have to drop. I’m a Toyota guy and all of them simply press - No drop.
Is there harm if I lower the two front hood circular bumpers too much to experiment?
Lifeliberty
Moonbeam👀
Columbus, OH
The 2 hood bumpers stabilize the hood at speed. If not adjusted correctly you'll notice the hood flapping about on the highway.
So you want them raised high enough that still allows hood to close. If too high you won't be able to close hood. Find the highest point that allows hood to close(with force)
They aren't really in there tight, they kinda float. I don't see any harm in adjusting them, they are meant to be adjusted. I wouldn't want to drive with them not adjusted to stabilize the hood, the hood would bounce and then that could cause wear
bradcd
Brad
Saab 9-3
Here are my trials and tribulations https://www.bronco6g.com/forum/threads/hood-bump-stop-info-causes-and-part-number.69160/
