Problems Reconnecting Drivers Door Handle
ScottSwayze
Austin TX
2022 Bronco
Hopeful someone has experienced a similar problem. I am doing a handle cover replacement on my Bronco. All of the covers went on without an issue except the drivers side handle. I have the new covers set properly, but when I try and reconnect the handle to the latch it won’t grab. If I try and tighten the 5 mm bolt it just pushes the handle further out. Any recommendations before I have to take the door apart?
Any help is greatly appreciated!
Ford Bronco Problems Reconnecting Drivers Door Handle 87503897-82CC-45B3-9703-99802CB66B77
Ford Bronco Problems Reconnecting Drivers Door Handle CB2C3892-DFB0-4C59-A1F8-E945788C219B
Ford Bronco Problems Reconnecting Drivers Door Handle 0401E814-4672-4021-86A2-58996E959516
Ford Bronco Problems Reconnecting Drivers Door Handle 25C1628A-5F66-4D40-A823-BAB1486F36C5
Beach Bronco
Oceanview, DE
2022 Bronco
Sorry I can't answer your question. Plan to swap my door handles too, but haven't seen any threads of how to remove and reinstall. If you time I would really appreciate any information and guidance on your install, and any fix to your problem.
Lifeliberty
Moonbeam👀
Columbus, OH
There is a video showing how to swap handles somewhere, fyi.
Lifeliberty
Moonbeam👀
Columbus, OH
BlueBronco
DFW
You may have to get some small picks and open the jaws. I had taken mine off and 2 went in by applying pressure and turning the 5mm bolt. The other two I had to open the jaws and then follow the procedure.
Mikejr66
SoCal
Follow the videos others posted. I ended up stripping the mechanism when I did mine and had to get it replaced at the dealer.
ScottSwayze
Austin TX
2022 Bronco
This was very helpful. Need to get a hook, but looks like the step I’m missing on this one. Thanks!!
ScottSwayze
Austin TX
2022 Bronco
Got it latched in. That last video did the trick with the hook tool. Thanks for the feedback everyone!
Romanenk0
BarbosBronco
Baltimore, MD
2022 Ford Bronco
did you end up stripping that 5mm screw? I did. How much did the dealer charge to replace and fix this?
