Remove the wildtrak vinyl door stickers?
rheuz
Bob
New Hampshire
2023 Ford Bronco
Is it as simple as using a hairdryer to heat up the adhesive, pulling, and then finishing up with some adhesive remover?
El Bronco Blanco
Matt
Scottsdale, AZ
2013 Ford Explorer XLT, 2021 Mazda CX-9
You probably won't need any adhesive remover, assuming you mean the badges on the fender....
If you mean the lower body line sticker, I have no experience taking that off, or the hood one either.
Ford Bronco Remove the wildtrak vinyl door stickers? 2
lapazleo
Indiana
2022 bronco badlands
Yep a little heat and finish up with Goo Gone or even rubbing alcohol.
da_jokker
Jeep Wrangler JKUR
That sucks...IIRC that was like a $500+ add on.
Heat gun and goof off would have you covered.
Bill K
Bill
Allen, TX
Ford Bronco Big Bend 2 Door
Like you I used a hair dryer, goo gone, and then rubbing alcohol for final clean up. Worked great.
CarGuy
New Jersey
2023 Ford Bronco
Same here…first thing i did when i brought it home.
bkirchhoff
Middlebury, VT
BMW: '07 328xi, '13 X1, '75 R90/6, '12 R1200GS
If removing the badge stickers with a hairdryer, is it possible to relocate them? Or is the adhesive toast after removal? I’ve been thinking about taking the Badlands badges off and would like to perhaps move them to the glass windows on each side of the hardtop. Then put Bronco script emblems where the Badlands emblems were.
604Bronco
British Columbia
www.bronco6g.com
Depending on what the weather is like where you live, if it's hot outside you could leave your Bronco parked outside for a while to help even further.
The trim badges can be re-used - I've seen several people re-attach them inside their Bronco or on things like coffee mugs, etc. Shouldn't be an issue. Worst case, if it's not sticking as well again as you'd like, add a tiny bit of glue (depending on what/where you are re-attaching it to).
Seahund
Adam Webber
Carlsbad, CA
Chevy Tahoe
Super simple, heat up with hair dryer, peels off easy & takes the adhesive. I put one on a thermos and other on my rear window. 2dr Badlands
El Bronco Blanco
Matt
Scottsdale, AZ
Ford Bronco Remove the wildtrak vinyl door stickers? 3
Yep, simple to reuse. I put one of mine on the back of the Bronco on my tailgate reinforcement. I simply stuck mine to my laminated window sticker, in the meantime since I did the fender badge one weekend, and the tailgate reinforcement the next. Re-heated it up with the blowdryer and peeled it right back off.
