Reverse lights not working
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
Anyone have the reverse lights stop working? Is there a dedicated fuse ? @Ford Motor Company ?
flip
Phil
IN
www.ruxerparts.com
Fords
Has anything been done to the vehicle recently? Modifications? The reverse lights are controlled from the transmission range sensor, through the PCM, gateway module, BCM which powers up the lights.
Anything else not working since this happened?
Ford Bronco Reverse lights not working 1690802009699
Ford Bronco Reverse lights not working 1690802351115
BroncoA512021
BroncoA512021
Long Island, NY
www.facebook.com
The rear camera occasionally does not come on. I can turn on my aftermarket reverse lights with an aux switch that also come on with the reverse. All else is working fine. The baja reverse lights have been installed for about 8 months. This issue just started.
whmoorejr
Friendswood
2023 Black Diamond
Did you use diodes with your baja lights? If not, when you turn them on with Aux, it will back feed the stock reverse.
BroncoA512021
BroncoA512021
Long Island, NY
www.facebook.com
I have had the baja lights for a year and this just started
Coronabronco
Julio
Miami
Bronco Badlands
Any solutions?? This just started on mine
