RH4x4: Zero Compromise Bronco Front Bumpers
ROCK HARD 4X4
RockHard4x4
St. Paul, NE
www.rockhard4x4.com
We took some serious time getting these Bronco Front Bumpers right. They are compatible with *EVERY* factory option with no relocation required!
Compatibility:
  • Every Bronco Trim Level
  • Forward Parking Sensors
  • ACC Radar
Our Bronco bumpers are available in two flavors, 1/4" thick heat treated aluminum or 3/16" heat treated steel.
They're as close to your frame rails as we could make them for maximum approach angle and line up fantasic with your fender flares.
Features:
  • Total OEM Compatibility
  • Factory Fog Light Mounts Available
  • Powder Coat Included
  • 100% Bolt On
  • 100% Made in the USA
  • Flat Towable (with associated brackets)
  • 1" Thick Double Welded Recovery Tabs
We figured out Ford's parking sensor recipe so our in house produced sensor mounts work with both styles of Bronco sensors (bet you didn't know there were 2 thicknesses) so you won't have a wobble and false alert issue with our bumpers.
Each bumper includes powder coated wing plates for fog light deletes, or you an opt for our aftermarket light wing plates to mount cubes or pods.
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers rh-60210-2T
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers rh-60210-3T
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers rh-60210-4T
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers rh-60210-5T
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers rh-60210-8T
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers rh-60210-9T
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers RH-60210-H-2
Loaded with Options
  • Winch Plate
  • Camera Relocation Hoop with Light Mounts
  • Flat Tow Bar Brackets
Winch Plate
Our optional bolt on Bronco Winch Plate gives you the opportunity to install a self-recovery winch. It includes 2 plug and play parking sensor adapters so you can relocate your 2 center sensors forward.
Click Here to Learn More
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers RH-60211-2
Optional Camera Relocation and Light Hoop
If you've added our winch plate and have an optional Ford forward facing camera, add our Camera Relocation Hoop and Light Mount to keep your camera eyes forward and help you wheel past sunset. It's also 100% bolt-on and includes a plug and play camera harness and washer squirter extension.
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers RH-60212-2T
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers RH-60212-3T
Flat Tow Tow Bar Brackets
Click Here to Learn More in this Thread
Ford Bronco RH4x4: Zero Compromise Bronco Front Bumpers RH-8002-BO-2
stuckinohio
Columbus Ohio
2 Door Badlands, MT High 2 Dr, V6 Outer Banks, Lux
Glad to see you guys producing for the Bronco. I installed your full width aluminum front bumper on my JL and LOVED it!
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Wow. Looks like y’all took into account a lot of things. But, and I could be missing it, what about ACC with the winch plate?
telenerd
Laramie
Subaru
Any plans to release a rear bumper?
Also, I have the capable bumper with fog lights. Will the lights fit in your bumper? Thanks
ROCK HARD 4X4
ROCK HARD 4X4
RockHard4x4
St. Paul, NE
www.rockhard4x4.com
Fog lights - Ford is letting us know if they're changing fog mounts in next model year, otherwise all RH4x4 front bumpers will have optional plates to mount your factory fogs, if you have factory fogs. Existing RH4x4 bumpers in the field will get our factory fog light mounting plates if you ordered them mailed to them once they are released.
It'll be a very easy change out since mounting the fog light mounts can done after the bumpers installed anyways.
ROCK HARD 4X4
ROCK HARD 4X4
RockHard4x4
St. Paul, NE
www.rockhard4x4.com
Just hadn't had a moment to post the 3 rear bumpers we make on the forum yet. Will do yet today.
Mack50036
Duane
Iowa
2008 F250 Crew Cab Long Bed
Have you considered offering a front mount receiver for winch or plow mount?
ROCK HARD 4X4
ROCK HARD 4X4
RockHard4x4
St. Paul, NE
www.rockhard4x4.com
I'll bring it up to James in the morning. I don't see a low winch mount or receiver not blocking the ACC feature, and we really want to offer a bumper that works with all Broncos on the road.
ROCK HARD 4X4
ROCK HARD 4X4
RockHard4x4
St. Paul, NE
www.rockhard4x4.com
Factory fog light mounts are done, photos soon. With our mount you can also adjust the angle the fogs sit at for a wider beam effect.
LowerSlowerDelaware
Lee
Lewes, Delaware
Subaru Outback, Chevy S10 Ram 3500
Any bigger hoop or brush guard options?
Need to protect my grill from all the damn deer around these parts.
ROCK HARD 4X4
ROCK HARD 4X4
RockHard4x4
St. Paul, NE
www.rockhard4x4.com
Hadn't considered a bigger one, mostly because we wanted to keep the camera angles similar to OEM.
