Rock Slide Engineering EZ Rack
wetdog
Bruno
pacific coast
2019 jl
Not a bad idea and non permanent you don't have it on all the time getting rusty.
I would do this before putting gas on the roof or in back directly exposed to a hit from a car.
Worst wreck I ever saw was a rear end at a light and the truck had a full Jerry can in the back tire.
ICUGAZN
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Very good points. Only strap it on when going off roading
BronchoPeat
Pete
Ohio
www.evergreenclothier.com
'18 Tiguan S w/4motion | '14 Fiesta SE Hatchback
I’ve been thinking about picking this up as well. I was hoping to be able to mount over the side windows on the clamshell but this could be the simplest solution and very easy to remove when not in use.
ICUGAZN
ICUGAZN
Kevin
2019 Raptor
BronchoPeat
Pete
Ohio
I've been thinking about this as well. It can be removed when not in use as well. The only thing with it is you have to remove the rear brake light when installed. Not sure how easy that would be.
M.A.S.S. Spare Tire Platform (STP) - American Adventure Lab
I was going to do this but had a couple concerns:
1) added weight to the tailgate door and how it would hold up.
2) with the fuel container seemingly right up against the door handle, wouldn’t that prevent operation of the tailgate?
I could always stack 2 on the right but just had some thoughts. The tire shelf is awesome though.
Bschurr
NY
ICUGAZN
ICUGAZN
Kevin
2019 Raptor
Yuuuuup - great product & terrific solution. I have used on on my JKU but haven’t strapped it on my Bronco yet however, I have confirmed that it does fit!
Nice. You always carry 2 fuel or do you mix it up?
Bschurr
NY
Yes, 2 x 2 gallon fuel containers on the outside. Water and First Aid on the inside.
aphillips66
Andrew
NH, USA
2022 Ford Bronco Black Diamond
I don't suppose the Jeep JK tailgate hinges are the same dimensions as our Broncos?
RotoPax mount
Ford Bronco Rock Slide Engineering EZ Rack IMG_6131
Bschurr
NY
