- Adam
- Aug 30, 2021
- 355
- 4,383
- 5,847
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
Ever since the Bronco came out there was always talk about CHASE LIGHTS. Baja Designs and Diode Dynamics both offered a reverse kit that COULD also be used as a Chase Light. It's a terrific system because normally they act as reverse lights but when you want them to act as chase lights, throw some amber covers on and you've got chase lights.
BUT, some folks wanted MORE then that. So SDHQ to the rescue. SDHQ makes some really terrific mounting systems and we've actually been a stocking dealer for them for a number of years. They now have a Chase Light Solution for the TRUE ENTHUSIAST. It combines a pair of Baja Designs S1/S2/Squadron lights with one of the Baja Designs RTL bars to give you a really unique chase light and 3rd brake light setup.
https://www.4x4truckleds.com/sdhq-3rd-brake-light-chase-light-mount-for-2021-ford-bronco/
ELEVATE YOUR BRONCO: SDHQ'S 3RD BRAKE LIGHT CHASE MOUNT
Boost the functionality of your 2021 and beyond Ford Bronco with the SDHQ Built 3rd Brake Light Chase Mount. This precision-designed mount seamlessly replaces the OEM 3rd brake light, offering compatibility with a range of Baja Designs LED lights for an optimized chase light experience.
VEHICLE FITMENT:
SPECIFICATIONS
VEHICLE FITMENT:
- 2021-Present Ford Bronco and Bronco Raptor
- Suitable for 16”/17” wheels with backspacing up to 6.1875” (+55mm)
- Fits OEM 16” Steel Wheels and tires up to 40”
- 3rd Brake Light: Baja Designs Rear Tail Light-Mini RTL-M LED Light Bar (6in)
- Chase Lights: Baja Designs S1, S2, Squadron Sport, and Squadron Pro LED Lights
- Expertly engineered and 3D CAD designed in-house, ensuring the trusted SDHQ quality, fit, and finish.
- Robust 3/16” Aluminum construction for durability and lightweight performance.
- Fully replaces the OEM 3rd brake light.
- Stainless steel hardware for long-lasting corrosion resistance.
SPECIFICATIONS
- 3D CAD designed, engineered & built in-house for our typical SDHQ Built quality, fit, and finish
- Completely replaces OEM 3rd brake light
- 3/16” Thick Aluminum construction for weight and durability
- Designed for Baja Designs RTL-M to replace 3rd brake light and S1,S2 or Squadrons to be used for chase lights
- Stainless steel hardware provided for ultimate corrosion resistance
- Designed to work with 16”/17” wheels with a maximum backspacing of 6.1875” (or +55mm)
- Fits all OEM sizes of tire as well as 37” & 40” tires
