BCKMRKR
James
NorCal
'22 Wildtrak 2-Door, '19 Miata, '15 M235i
I’d have to say most everything you’ve stated is correct. The tire’s weight is a huge contributor to rotational mass. This primarily affects acceleration & deceleration. The wheel and tire’s linear travel on a single axis.
The other aspect of vehicle dynamics around suspension and steering is unsprung mass. Basically everything from your tire touching the ground all the way to your suspension pick up points on the frame. Steering response, steering effort, bound, and rebound of your suspension, among other things. Essentially the other two axis of a three dimensional equation.
In these two axis, static weight of the entire assembly is paramount. Your wheels, once you’re at speed, are now large gyroscopes. The lower the overall unsprung mass and rotational mass, the less effort is required to change the direction (up / down / left / right) of the gyroscopes. This is where you realize the weight savings of lighter wheels, wheel offset, lighter wheel hardware, and also overall diameter coming into play.
This is also very noticeable in cycling wheels and tires. When I upgraded my 2009 road bike (aluminum rims with rim brakes) to a new 2022 bike (carbon rims with disc brakes), the tire/wheel weights were very similar but the performance difference was very noticeable as a significant amount of the weight was moved from the rims (which needed to be strong and heat resistant for the brake pads) to the discs that were much closer to the axle.
mcinfantry
Lee
Louisiana
Badlands 2 door
Interesting
What was the change? As in performance change or felt change
TeocaliMG
Plymouth Michigan
www.brokeninnovation.com
2021 Bronco Badlands non-sas 4 door manual
Icon rebound pro are positive offset, i run them
I was looking at those, definitely a very clever idea. I still wouldn't classify it as a true beadlock, but it probably performs essentially the same in most conditions.
mcinfantry
Lee
Louisiana
Badlands 2 door
I have first hand experience with
Hutchinson (double beadlocks)
USA6x6, stazworks double beadlocks
Marsh traditional beadlocks
Icon rebound pro
the Hutchinsons are absolutely in every way the best. I’ve run 0 psi intentionally and no issues
I routinely run 6psi on the icons no issues
I haw zero issues with icon vs traditional other than no tire is made to be clamp sealed the way traditional beadlocks work. I see no difference on performance on those two styles
Edit… I may or may not have also tried screws as a young man with dumb ideas….
BCKMRKR
James
NorCal
Interesting
It was both. The performance change was that the wheels are much easier to accelerate and change direction (since a large % the weight had moved from the rim to near the axle) as there is less gyroscopic forces (not sure if that is the term) to fight them. The change in feel is that this could be considered somewhat of a negative at high speed (like a 45 mph downhill) as they feel a little less stable over bumps and with wind gusts, which took a little while to adjust to.
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
Where do you find the time?
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
What fog lights are these? Thanks!
Those are our Hammer Built Flush fit fogs that use Baja Designs S1s! Currently we have a 4 light kit available, but that 3 light kit that Austin is running will be available soon!
We are very excited for this build and very thankful that Austin will be able to show off some of our products at SEMA!
Fordgirl2003
Misty
MO
2003 Superduty
Thank you! Looking forward to that 3 light version! Enjoy SEMA!
rzshootr
Walter
Los Angeles
Audi A3 Etron
Fantastic build. I love the clean mounting of the four lights on top of the bumper. How do you mount all four of those? I get how the outer two lights mount using the existing holes on the bumper, but what about the inner two? Do you have to drill into the bumper to mount the inner two? Or is there a bracket that holds all four? Looks like a great design. Thanks!
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
Barny227
Brandon
Wy
2014 wrangler jk
My favorite build to date.
Rezzak
Scottsdale
We’ll see you in a couple weeks! If you’re attending SEMA, please, stop by and say hi! We’ll be debuting our new billet machined wheel line. We have specific designs with the Bronco in mind. Austin Berendes’ awesome build will be in our booth with a brand new set of billet bead lock wheels installed.
We’ll also have our current Bronco accessories installed on the Bronco and quite possibly some brand new gear!
See you there!
Please DM me a link to the build list? This is amazing. Would love to see these fenders and wheels etc on a Bronco Rapt
eqlol
Everglades
JP
Los Angeles
2023 Bronco
Everglades
What light bar is that?
paleh0rse
Bronco and others
I'm very interested in that entire lighting solution. The round lights look sick!
