SFR Chase Light / Dust Light / Reverse Light Brackets
StinkBug
Dallas
Too Many
A number of customers came to us, frustrated that the only rear facing light brackets they were finding all mounted to the spare tire lugnuts. Meaning that in the event the spare was needed, you'd have to take apart the light bracket. Plus they couldn't put a tire cover on if they wanted to. We agreed with them, and got to work on these. Our new Chase light brackets attach to the door, behind the tire, so they have absolutely no effect on removing the spare if needed.
The other complaint that they had about other mounts was that they were too expensive, and we hear this about a LOT of products and always do our best to challenge the competition. Again I feel we succeeded here with a set of brackets that do the job at a reasonable price.
These fit Baja Designs S1 or S2 lights mounted under the bracket with 35-37" tires or larger lights / larger tires with the lights above the bracket.
In stock ready to ship now at https://www.stinkyfab.com/products/chase-light-reverse-light-brackets-for-bronco-6g , and as with all of our products these are made right here in the USA.
Ford Bronco SFR Chase Light / Dust Light / Reverse Light Brackets Chase1
Ford Bronco SFR Chase Light / Dust Light / Reverse Light Brackets Chase2
Ford Bronco SFR Chase Light / Dust Light / Reverse Light Brackets Chase3
Ford Bronco SFR Chase Light / Dust Light / Reverse Light Brackets Chase4
Bschurr
NY
Interesting - are they Braptor compatible? And, what’s the distance between the mounting holes if I wanted to mount a light bar across the top?
StinkBug
StinkBug
Dallas
Too Many
I have not test fit on a Raptor yet, so I cannot confirm. There is a little adjustment in the mounting holes, but I just measured on mine and the mounting holes are 11.25" apart. The flat surface is plenty large enough to drill new holes as well, overall width is ~14.25" with 7.5" between the brackets
ScLeCo
Springfield
Charger Hellcat
Too bad it's not height adjustable. Some of us have 40" tires.
