Tail Light Replacement - is the clear cover alone replaceable?
rainman23
Ray
Salem, OR
F-150
Had a little issue today and backed into something that broke the clear cover on my driver side tail light. The light still functions like normal. I would like to fix it, but I have already seen the cost of the OEM assembly and am trying to see if there’s an alternate solution. I haven’t removed it yet to see, but I’m curious if any of you know if the clear cover over the assembly is replaceable or if it is part of the $1k tail light assembly (signature). It looks to be part of the assembly and not replaceable on its own unfortunately. If it is replaceable I haven’t been able to find the part number yet.
OracleLights
New Orleans, LA
www.oraclelights.com
To help avoid damage in the future, check out our Flush Style LED Tail Lights. They are specifically designed to help avoid potential damage from trail riding (or elsewhere) and greatly out preform stock tail lights with 1,400 Lm of reverse light output! Let us know if there is anything else we can help with and use discount code forum10 for 10% off your entire order!
https://www.oraclelights.com/collec...flush-tail-lights?_pos=1&_sid=27ddae444&_ss=r
Ford Bronco Tail Light Replacement - is the clear cover alone replaceable? 52276902126_4e1ecd585e_h
