Test run: hyperdip brass monkey Beauty ring
foreWard
Ward
RVA
2022 Badlands
Been thinking about a bronze wheel for my shelter green raptor. Had this in my garage from a previous project. Just tried it on the spare for now, but kinda dig it! Has a metallic flake in it like shelter green, but is a very dark bronze. Also redid the bolts as they were fading, haven’t tightened them all the way back down yet so they and the dip have more time to dry.
Ford Bronco Test run: hyperdip brass monkey Beauty ring IMG_0747
bdubsbronco
Brandon
Georgia
Ram 1500
I have me four rattle cans of the bronze plasit dip just WAITING on spring to do the same thing. Plus I have a matte army green to do the whole thing. jonesin' for some spring temps
NMWildtrak
Keith
Rio Rancho, NM
2022 Wildtrak
The whole truck or just the wheel?
bdubsbronco
Brandon
Georgia
Ram 1500
The whole truck. I've done it in the past when I had a Wrangler. Actually painted it four different times/colors. It was burnt orange, khaki, like a denim blue, and a pearl white. It takes either 2 gallons in a sprayer or about 15 rattles cans. Fun weekend project! haha
NMWildtrak
Keith
Rio Rancho, NM
2022 Wildtrak
Pics or it didn't happen! 🤣
Seriously, once you get it done, postem because I've thought about doing something similar but got turned off by the cost of having someone else do the work for me.
bdubsbronco
Brandon
Georgia
Ram 1500
It's REAL color was "Rhino", a really dark grey/blue. The only real things to keep in mind is, always keep the rattle can or sprayer moving or it will drip. And PUT IT ON THICK. That makes it easier to peel later. I learned the hard way with the first one which was the Khaki. I didn't put it on thick enough then it would just tear into little bitty strips or pieces as I tried to remove it. I ended up literally using a pressure washer to get all the tiny little pieces off.
Ford Bronco Test run: hyperdip brass monkey Beauty ring smaller
Ford Bronco Test run: hyperdip brass monkey Beauty ring orange smaller
Ford Bronco Test run: hyperdip brass monkey Beauty ring orange smaller3
Ford Bronco Test run: hyperdip brass monkey Beauty ring khaki smller
Ford Bronco Test run: hyperdip brass monkey Beauty ring khaki smller2
Ford Bronco Test run: hyperdip brass monkey Beauty ring dudebluesmaller
Ford Bronco Test run: hyperdip brass monkey Beauty ring whitesmller
NMWildtrak
Keith
Rio Rancho, NM
2022 Wildtrak
Those all look REALLY good! Look forward to seeing what the OD Green looks like.
foreWard
foreWard
Ward
RVA
2022 Badlands
Here’s the finished product on the other wheels. It’s very subtle, almost like I just blacked out the rings, but from certain angles the bronze shows up.
Ford Bronco Test run: hyperdip brass monkey Beauty ring IMG_0750
bdubsbronco
Brandon
Georgia
Ram 1500
Those look great. I love how it has a subtle color variation. I am getting antsy, I'm thinking I might try that this weekend but in reverse. So the inner wheel will be bronzed, and I'll leave the ring blacked out. What did you use to cover the tires when you sprayed? Or did you just peel them off the wheels afterwards? I can NEVER get painters tape to stick AT ALL to the tires
foreWard
foreWard
Ward
RVA
2022 Badlands
So I didnt need to mask anything off as I removed the rings and sprayed them separately. But in the past when I dipped wheels, I found that a deck of playing cards tucked between the tire and the rim worked really well. Just need to put bags behind the wheels to keep it off the brake/hub/etc.
