THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics SOo3LRY
Diode Dynamics is excited to introduce the SS5 LED Pod!
Featuring the highest output intensity of any 5-inch LED pod on the market, these auxiliary lamps have been designed for maximum functionality, with patented technology and custom-engineered TIR optics, all in a durable package. This high-output 5-inch pod can add tons of light on bumpers, ditch mounts, grilles, and more!
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in the SS5 collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency.
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics KZ8HCRv
From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the SS5 serves as both the optic and main lens for greater efficiency and light output. Thanks to this patented and innovative technology, when coupled with high-intensity LED chips, the total intensity of the SS5 is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
Selectable Backlight. The Stage Series 5" LED Pods included in the White kit feature a selectable backlight with eight different color options, perfect for an extra styling accent, or for more visibility when you’re not using the main beam. Selecting your backlight color is easy - simply alternate the power on and off. There’s no complicated programming with a controller! The SS5's backlight fully illuminates the TIR optic, providing unique accent lighting that you won't find on other LED pods.
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics oNAvE39
NOTE: Due to the yellow lens, the Yellow kit is only available with an Amber backlight color.
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics WWa6AT
CrossLink. Our patent-pending CrossLink technology allows you to link up to eight SS5 pods together to create your own lightbar.
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics cf9VfaQ
Unlike other options on the market that use multiple pieces to link pods together, we have designed a single-piece CNC aluminum link. This provides extreme rigidity, but is fully adjustable, for both straight and curved configurations. And thanks to inset threaded mounts built-in to every SS5, there is no need to buy a special linking version of the SS5 for your setup.
Click HERE to shop SS5 CrossLink Lightbars!
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics ZocRvhw
Image courtesy of Panda Motorworks - SS5 Sport - Spot Beam Pattern
Note: These output shots feature ONLY 2 SS5 Sport LED pods!
Functional Patterns. Stage Series beam pattern options were designed with advanced optical simulation modeling, to shape the output in highly-functional beam patterns with high efficiency. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you!
  • Driving is great for general illumination at speed. Rather than a traditional "spot" pattern, the Stage Series Driving pattern shines in a 30x20 degree spread, providing just enough width to fully illuminate the road ahead at high speeds, but still staying focused to avoid too much foreground light. Although the SS5 Driving is too bright to be considered an SAE Auxiliary High Beam, it is perfect for an extra boost of light at speed.
  • Combo pattern combines both the Driving and Flood optics, perfect for all-around use. It shines light downrange in a focused 30x20 Driving beam to punch with distance, and fills in the surrounding area to create a full 70x30 degree pattern. With a row of driving optics in the middle, and a flood optic on the top and bottom, this has been designed to provide extra light for every situation.
  • Flood pattern was designed to provide uniform, even illumination with a full 70x55 degree spread of light. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout. It is perfect for lighting up anything at low speeds, or for trailers and worksites.
  • Spot is an unmodified pattern, shining light directly from the TIR optic. The result is a highly focused 15-degree beam of light, perfect for directing light far into the distance. With an incredible output of 406,000 candela, the SS5 Sport shines a mile away (ÂĽ lux). NOTE: The Pro Spot uses a larger LED emitter, which spreads the light output into a 20-degree pattern. Although the Pro has much more raw output, the larger beam pattern results in slightly lower total intensity.
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics Wl6fQ0E
White or Yellow. Stage Series SS5 LED pods are available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics uRXJLqL
Sport or Pro. Stage Series SS5 LED pods are available at two different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The Sport model uses nine high-intensity LEDs for 40 watts of total power. The Pro model steps things up in a big way, with over double the total power at 90 watts.
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics RJD0Pwv
Simple connections. All SS5 LED pods feature an integrated and waterproof DT type Deutsch-style connector on the back, and come with a 6-inch pigtail with bare leads. For installation, you can wire yourself, or select an optional Diode Dynamics wire harness.
In The Box:
  • Two (2) Stage Series 5” LED Pods
  • Two (2) Deutsch-style wire pigtails
  • Two (2) Mounting brackets and hardware
Snap-on covers. For states that require them, or for extra styling or protection, we also offer snap-on covers for your SS5 Pod. These covers are available in a variety of colors and keep your SS5 Pod clean and protected from dirt, dust, or whatever else the road throws your way!
Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like your factory lighting components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email [email protected].
PM us for the free-shipping code (U.S. forum members only)
John C.
Diode Dynamics
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics U5mUIFL
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics gV5meLU
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics y3o0QGs
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics U77Botf
Gary5393
GARRETT
Maryland
Kia soul
Any word on if you will have a kit with mounting hardware for installation with a roof rack?
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
We don't have any plans presently to build a kit to accommodate roof racks.
However, I will pass this information along to our engineering team.
If your roof rack doesn't interfere with the accessory mounting points above the windshield, then our SS5 Windshield CrossLink Lightbar Kit for the 2021 Ford Bronco is available for pre-order.
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics image_50397953 (1).JPG
John C.
Diode Dynamics
Gary5393
GARRETT
Maryland
Kia soul
Unfortunately it does. I was hoping for something like what rigid has.
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics 46725-ford_bronco_roof_rack_mount_lifestyle-01
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Ford Bronco THE WAIT IS OVER...THE SS5 LED IS HERE | Diode Dynamics KFv8bbK
Now’s the time to upgrade your ride! Our Black Friday Sale is going on NOW! Save 15% sitewide, including our new SS5 LED Pods and CrossLink LED Light Bar Kits, by entering coupon code “BF21” at checkout! And, all orders over $500 will receive a free Diode Dynamics long sleeve shirt! Sale ends Tuesday, 11/30/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 11/30/2021.
Cannot be combined with other coupon codes.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Just a heads up!
All SS5 LED pod orders through 12/31 will receive a FREE snap-on cover for every SS5 pod purchased!
SS5 snap-on covers will automatically be added to your cart during checkout. Limit 1 per SS5 pod.
Don't forget, you can also send us a direct message for a free US shipping code!
John C.
Diode Dynamics
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Just a quick reminder!
This is your LAST CHANCE for a free snap-on cover with your SS5 purchase, on us! Don't miss out, preorder your SS5s today before 12/31 at 11:59pm CST!
Stage Series LED pods featured in the image above: SSC1, SSC2, SS3, and SS5.
Click HERE to shop SS5 LED pods!
John C.
Diode Dynamics
Draughon
Daylon
Dallas
BMW 4-Series
These look awesome...but I still want a round enclosure. ;-)
kkurni
WA
Mini Countryman
Does Yellow cover enough to be road legal in Washington?
Or does it have to be black cover?
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
We don't have any plans for an SS5 round bezel at this time. However, I've put in a note to our engineering team regarding your request!
You will need to check your local laws and regulations for the state of Washington.
In our experience, states that require covers on after-market LED pods or lighting require black caps/covers.
Headsong
Adam, any word on our SS3 kits? Ordered mid-Dec. Don't even have my Bronco, but just wondering....
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Our Stage Series Fog Pocket Kit for 2021 Ford Bronco is a pre-order product and will ship on January 28, 2022.
John C.
Diode Dynamics
Headsong
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
Here is a closer look at our SS5 LED pods featuring our combo optic!
If you had to choose, which color output would you go with? 3000K selective yellow or 6000K cool white?
John C.
Diode Dynamics
