does anybody have any tips or tricks to reinstall the soft top windows? Every time I take them out it is a pain to get them back in. I have watched so many videos on YouTube, but they make it look so easy. Any tips?
whats giving you the hardest time ?does anybody have any tips or tricks to reinstall the soft top windows? Every time I take them out it is a pain to get them back in. I have watched so many videos on YouTube, but they make it look so easy. Any tips?
yup!! right now I cant get it back in at all which is the problem.getting the side window to lock in the back window can be a pain but has to be tight so it wont blow out
try putting some rubber protective on the slide for a little lubeyup!! right now I cant get it back in at all which is the problem.
thanks!! will try!!I made this vid a while back, perhaps it'll help you. The important part is to press the back window's corner towards the front, start at the bottom and work your way up.
I’m having the same issue. Both side windows are always an 1/8 inch short. I’ve given up for the day. What did the trick for you?Well, I managed to get it in this morning, but, damn it was tough. Basically the side window is always 1/8 inch short from the rear window. I'm always afraid the plastic is going to snap. I'm wondering if there was some defect in the early soft tops.
