Unidentified Creaks HELP!
coreymay1
Corey
Atlanta, GA
2022 Bronco
Hey everybody - I have a 4 door soft top black Diamond. There is an unidentified creak that occurs at times when I shift poorly and when I go over minor bumps in the road. Driving me nuts. It doesn’t seem to occur when I have folks in the back seat. While the soft top is slightly misaligned, I don’t think it’s that, nor is it the tailgate. Maybe some bolts attaching the seat to the floor need grease? Anyone else have this problem and solve it? Thanks!!
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Ford Bronco Unidentified Creaks HELP! A33B47FC-A11B-4BDC-8DAE-46D85E69DE80
BostonGuy
Boston
Jetta
Sit in the trunk and have someone drive around the block. Or some type of semi safe road.
Safety CYA Note: Please note that im a trained professional and you should not try this at home due to risk of injury. Boston guy is not responsible for any injuries sustained in the identifying of creaks, cracks or other Bronco related injuries.
Herbie
Alex
Cleveland OH
2022 Badlands
Does it almost sound like a squeaky spring coming from the drivers side? If so, I have been trying to diagnose it for about a week and a half. I actually think mine is coming from the A-Pillar and I am taking it in to have looked at on Thursday. What is really strange about mine is that it stops after a good rain and then about a day later (seemingly after it has dried up) it starts again, which makes it more difficult to pinpoint as one would think if rain lubes it up so to speak then it would have to be on the outside of the vehicle. Who knows. It isn't terrible, just enough to be slightly annoying.
blanchardsbronco
Keith
Spring, Tx
ford fusion
on driver side just at back of front door. Look up under carriage. There is a bracket that holds the exhuast pipe. Check it. could be loose. That made a crazy squeak for me. But only because my dealer didn't put the bolts back on when changing my WHOLE ENGINE!!!!!!!!
Ksjrb03
Tx
F250
Ive fixed so many squeaks and creaks and rattles and pops I've honestly lost track. One of the first ones was a rear seat, and I found it by folding the seats down and the noises stopped. Some grease on the hinges fixed that one. Try folding the seats down and see if that helps.
coreymay1
coreymay1
Corey
Atlanta, GA
2022 Bronco
Thanks for the ideas. Yes, sounds like a squeaky spring behind drivers side. I’ve also noticed that on the rear passenger door, the latch bolted on is rusting (whereas none of the other latches are rusting). May make the no-squeak-after-rain situation make sense if that’s where the squeak comes from?
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Send a private message to us with your VIN and the name & location of your Ford dealership, along with some more details about your situation. I’ll look into this for you. Thanks!
VVSidewinderVv
Tim
Pittsburgh, PA
20 GMC Sierra
My soft top was recently adjusted so that it actually latches at the middle like it should. There's a lot of play in the latch though and it doesn't put tension on the pin so it rattles now. The mechanism imo is just cheaply made. It really could have used a single or double rotary latch (like those used on car doors) that captures the pin and holds it tightly. That would eliminate a lot of the issues the soft top has.
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
It’s a ford. You’ll never get rid of all the squeaks and rattles.
