Vintage grille in black
DarthLincoln
Chuck
Northern California
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
I ordered a Badlands 2Dr which was perfectly setup with all the content I wanted in a Bronco. My one complaint about it is the grille, which i dislike probably the most of all the OEM grilles. It’s pretty flat, the staggered grille patten is not classic, and it is painted in a semi-gloss gray paint that doesn’t match anything else on the Bronco. The Base/Black Diamond grille I think is the best one which has some depth and a classic grille pattern in carbon black.
Ford Bronco Vintage grille in black IMG_4093
When I saw @Manx 1st gen tribute build (a truly stunning build), I decided to replace mine with the IAG Vintage grille. Only one problem: IAG only sells the grille in gloss white. There are no other white parts on the Badlands, and I’m not going for a heritage-style build with white painted wheels & hardtop that a white grille needs. Instead the grille would look best in carbon black or maybe hot pepper red surround with carbon black center.
Before committing to a design for a paint shop, I decided to try Hyperdip removable paint to see what it would look like in an all carbon black color. This is how it came out:
Ford Bronco Vintage grille in black IMG_4110
Ford Bronco Vintage grille in black IMG_4103
Ford Bronco Vintage grille in black IMG_4114
MUCH better! I did try it with and without the orange lens covers. I also tried the red-color ”BRONCO” letters that IAG includes with the grille, but the letters are very blocky and don’t look as good next to the orange lenses. So I removed and transferred the letters from the Badlands grille. I think this would look great with white lettered tires.
The Hyperdip was easy to do myself and took about 1.5 cans of the Frozen Black. With left over paint I decided to blackout my rear bucking bronco emblem. Very simple: no tight masking required, instead just peel off the paint on the sheet metal and it trims itself at the emblem.
Ford Bronco Vintage grille in black IMG_4121
Ford Bronco Vintage grille in black IMG_4123
I’ll keep it like this for a while to see how long the Hyperdip lasts, then will probably have the grille professionally painted.
Mkass
I seen this done on chrome and it eventually wears off. Keep us updated
DarthLincoln
DarthLincoln
Chuck
Northern California
Will do. This is only intended to be temporary to experiment with how it looks in all matte black. That was the reason I went with the Hyperdip. I do really like the look, so i may leave it on a while before I commit to a final paint. I’m also interested to see how it lasts on the grille. Other than cleaning, I did not prep the original white painted surface in any way before painting.
I’ll leave the blacked out emblem at the rear until it wears off, but it‘s not exposed to debris like the grille is. The nice thing is it‘s quick to redo it as needed, and I can always go back to the chrome whenever I want.
DarthLincoln
DarthLincoln
Chuck
Northern California
If anyone is curious, here is a collage of various combinations I tried before final assembly. Top row compares the two stock grilles, then the middle and bottom row is the painted IAG Vintage grille with white or red letters, with or without the orange lenses.
Ford Bronco Vintage grille in black IMG_1680
Beach_Bum
Ken
St. Augustine, FL
If one wants the Heritage grill (FORD lettering, smaller slots than the IAG, and there are only 6 across without encroaching on the headlamps), one could always paint it like the mule we saw last year.
Ford Bronco Vintage grille in black 1695510394557
DarthLincoln
DarthLincoln
Chuck
Northern California
Nice. One of the things I don’t like about the Ford OEM grilles is the grille pattern doesn’t go all the way to the headlights, so there is a blank surface above and below the turn signals. if I went with an OEM grille I would choose Black Diamond over the Heritage. It has similar traditional grille pattern (tho 7 across), but it is recessed in the grille area giving more of a brow around the grille.
Ford Bronco Vintage grille in black IMG_1681
broncorik
Rob
I went a kind of similar route but bought Heritage grille which came in primer black and I painted it with a rattle can of satin special paint...and painted red letters gray. I wanted FORD and not BRONCO letters.
Ford Bronco Vintage grille in black 20230916_195123
Simple Man
G
PacNW
'11 Subaru Outback MT,'70 F-250 Ranger XLT
Here's my mix of the BD grill with VasherDesign's Classic
Ford Bronco Vintage grille in black BGrill1
Style F O R D letters.
Ford Bronco Vintage grille in black BGrill2
Lowcountry Bronco
William
South Carolina Lowcountry
Saw that before on Etsy, can you give a close up on the lettering please? I was wondering how they did the chrome around the red. TIA!
MEAT_GOD
Kuwait
22 Ford Bronco 2dr, 15 Maserati Quattroporte
Hey, is that a bag placed over a winch? If so, is it any specific kind?
broncorik
Rob
Limited-time deal: Winch Cover, Heavy Duty Waterproof Dust-Proof Winch Protection Cover, Ideal for Electric Winches 8500-17500 lbs, Indoor/Outdoor (21.5” x 9.5” x 7.5”) - Black https://a.co/d/6l9izu0
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRD
I did the horse on the tailgate with extra hyper dip I had as well after doing my trucks trim, it looks so much better than the satin chrome or whatever Ford has there.
Grill looks much better but I bet the outside rim color match would look even better.
MEAT_GOD
Kuwait
Sick, thanks! Glad it wasn't overpriced, as I'd have expected such a specific use-case item to be.
broncorik
Rob
I know, right? Tough to beat something under 15 bucks and it is holding up well...pretty heavy-duty for what it is.
