Washout Floor Turning White, Anyone Esle?
VirginiaHeritage
Frank
‘25 Bronco HE
I fully expect to be hearing about that for years. Never posting again when I’m into a bottle of Jameson.
2023bronco
location
vehicles
Blooming doesn't typically go away permanently. Once it starts, it tends to become a "thing." But I'll hope otherwise for the sake of people with the rubber flooring.
SpringTXOR
The Woodlands, tx
1986 Bronco XLT
I fully recommend Armorlite! Hands down the best accessory I have purchased.
iamcris
Cristian
Lakewood, WA
21 Bronco Badlands
Mix 15.5 oz. Of 90% isopropyl alcohol and 5.5 oz of Glycerin. Mix, shake, rattle and then wipe in with sponge.
I'm not a professional but would advise to test it in an inconspicuous area. Wait a day/three/10 and have at it once you have confidence. Again not responsible for Internet expertise just a friendly suggestion.
/tiphat.
***EDITING TO ADD.....test it on an old rubber floor mat first, then stand back and be amazed.
BigHoof
PA
Ram 2500
I have never “washed out” or hosed out the floor. Again it is not a big deal. Just curious as to whether or not others have experienced the same thing. It is very odd and does not clean either.
Mine was the same. Never washed as well. A little 303 and was back to looking new.
Armorlite_Kail
Kail
Austin, TX
23 Bronco 4dr WT, 18 JLU Wrangler, 18 JKU Wrangler
Automotive flooring manufacturer here, this is 100% not caused by the owner. This is a material issue.
When we developed Armorlite we purchased a Bronco that had the factory washout floor, it had the same issue it was often present in areas that did not get touched as much. I tried a variety of cleaners and was not able to get it off. I did not try the LA's Finest cleaner recommended by the TSB.
I will note that the Armorlite floor is not the same composition, ours is a TPO, it does not do this, it does not fade, stain or discolor. Our unique cleaner also restores any discoloring left from other cleaners like dish soap.
OP, I would buy the cleaner mentioned in the TSB and give it a try. But know this is nothing you are doing to your Bronco. Best of luck!
BeachTiger
Joe
South Carolina
2019 Ford F150, 2022 Bronco Badlands
My '22 BL has also been doing this for a while, though not nearly (yet) to the extent yours has. Like you, I've never washed out the floorboard with anything. Maybe I've wiped it off a few times with a damp cloth.
Danielsand
Daniel
Idaho
'21 OBX SAS
I was pretty tempted to try this (my Tuxedo is a very good looking boy). After much deliberation (and several sleepless nights), I decided I really don't want any kittens.
