My point was is there aren’t speakers in the doors since if you remove the doors the speakers are also removed.DS-18 makes coaxial door panel kit for their speakers
How are they wired into the sound system?DS-18 makes coaxial door panel kit for their speakers
You are correct. I meant just the door speakers in my Ram alone before I did the subs and all it was so crisp and clear. I will be more clear next time.Kick panels, there aren’t any speaking in the doors.
Which MTI box did you get? The Stinger? The description reads that your sub if incredibly efficient with it's shallow shape. Also, did your JL audio C2-400x, manage to fit in the dash properly? Crutchfield keeps insisting that they do not fit. Sorry for all the questions: I'm currently installing C2's throughout the vehicle, and could really benefit from your opinion. Thanks!I am in the process of redoing my whole audio system. JL audio C2-400x top of dash & pods, JL C2-650X kick panels, MTI sub box with JL 12TW3-D4 sub in tailgate. JL amp with DSP. Will bi-wire speakers to make into component for better channel separation and sound stage. I would have preferred Focal speakers but they do not make a 4 inch coaxial. The issue I am told is if you go 6.5 component in kick panels and tweeter up top is there is too big a gap to get it time aligned with the DSP, that is why I am going coaxial and bi-wiring, this is as close as you can get to component sound. For less money plugnplay kits has a system for $1770 that will give you a nice set up. MTI has stage 1-2-3 for the bronco that i think is very good except they do it all with component speakers.
What speakers you put in yours?Just a quick note for those doing or wanting to do the rear pod upgrade, Mabett has the rear 6.5 pods on Prime day for only $109!! Grab them while you can!
https://www.amazon.com/Mabett-Speaker-Compatible-Accessories-Interior/dp/B0BLYMPH1R/ref=sr_1_1_sspa?crid=FPNHNKCA5XSK&keywords=mabett+speaker+pods&qid=1689085319&sprefix=mabett+speaker+pods,aps,195&sr=8-1-spons&ufe=app_do:amzn1.fos.304cacc1-b508-45fb-a37f-a2c47c48c32f&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
I went with Hertz X-170. I had originally intended to use the Infinity REF, but the tweeter sticks out too far and the grill will not mount. Just have to make sure it's a 6.75 speaker (actual diameter is 6.5"), the 6.5" speakers (6" diameter) will not fit.What speakers you put in yours?
