Where do I drill
nipeej
Rick
Dewey, Arizona
Honda, Toyota, Ford
I need to run a Cat5 cable from my radio control on the dash to the main unit on the passenger side console. Where can I drill on the dash to run this cable?
Any help would be appreciated. Rick
Ford Bronco Where do I drill 20230704_083006
Ford Bronco Where do I drill 20230704_085230
Copperhorse73
Justin
Mooresville, NC
That whole area underneath is hollow if u don’t have the lux package speaker there. I’ve done several USB hub installs, I usually just drill in the middle
Ed Morris
Ed
Longmont, CO
Jeep Grand Cherokee
If you want to see what you're doing before you drill, I'd suggest unscrewing the accessory mount panel and prying out the hero switch panel. You'll then be able to shine a flashlight under the tray you're drilling into to verify you aren't going to hit anything.
Kyukidoeric
Panama City Beach Florida
2022 Bronco (former 69 & 77 Bronco owner)
I loosened the top So I could see the underside, then hand drilled it with a tapered hole bit. It cut easy by hand. There isn't to much to getbin the way, but it was hard to feed the wires.
Ford Bronco Where do I drill IMG_20220724_175736451
