Which if these amp ratings is correct?
Draughon
Daylon
Dallas
BMW 4-Series
Trying my luck installing a pair of KC Pro6 A-pillar lights this morning and the plan was to wire them into the Aux 3, 10amp circuit... but this other chart shows that Aux 4-5-6 are all 5 amps, instead of 10?
If the bottom chart is correct, then I'm thinking I should put them on AUX4 since I only have one 30, 15, and 10amp circuit.
Help!
I have a '23 Badlands w/ SAS and the upfitter switches pre-installed.
Ford Bronco Which if these amp ratings is correct? Aux Switch Amps
Also terrifying to me (I've never done electrical before) is that the KC youtube video non-chalantly says, "Oh, just cut off this half of the wiring harness and wire up the red wire and the ground and you're good to go...."
Ford Bronco Which if these amp ratings is correct? wiring cut
Pray that I don't hurt myself or my rig this morning!
userdude
Denton, TX
2023 2dr Badsquatch
Where did you find the wiring information?
Draughon
Draughon
Daylon
Dallas
BMW 4-Series
Had it saved from various searches on Bronco6g... I just happened to notice they were different this morning so decided to ask the hivemind!
Draughon
Draughon
Daylon
Dallas
BMW 4-Series
Hey! It worked!
No cuts, and it lit up the first time!
Ford Bronco Which if these amp ratings is correct? IMG_7050
Ford Bronco Which if these amp ratings is correct? IMG_7052
