Why is the factory rack not compatible with 4 door badlands with 2.7 engine?
dmannx
Doug
Carlsbad, CA
2016 Land Rover LR4 / 2021 Ford Bronco Badlands
I see they are becoming available on the Ford Accessories page. But what is the reason for the compatibility issue?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
The added weight stresses the engine and causes it to munch a valve?
It's actually a GVWR issue. Well covered here if you search for that acronym.
Detroit0486
Matt
SVT Lightning, Audi S7
This ☝ Badlands is a heavy pig with the 2.7 and the electronic sway bar disconnect, hence why you couldn't add the roof rack option on the First Editions either.
Now this is from a factory order standpoint when ordering a Bronco, if you're looking to adding it after the fact there's nothing stopping you compatibility wise for installation, no difference in hard top design at all, but Ford is covering their tail here liability wise.
