Will these wheels work with SAS/offset correct?
chtucker
Kirkland, WA
FJ Cruiser
I see this wheel offset as being 5mm different than stock, they will stick out only 5mm more, stock wheels are 30mm correct?
Ford Bronco Will these wheels work with SAS/offset correct? B090F958-D246-44D6-B43C-0B9EAECD11A1
HoosierDaddy
__ Eric
Correct as far as I can tell.
Next is to put the bare wheel on the vehicle to make sure it clears the calipers etc etc.
chtucker
chtucker
Kirkland, WA
FJ Cruiser
Probably not going to get the chance if I go with these. I am being offered to buy some first/porotype wheels from a respected wheel maker. I trust them that they would make it right if they don't fit. Just double checking as I get confused constantly with positive/negative offset.
I like they are hub centric
buzpro
Binky
Tacoma
I think the hub bore on the Bronco is the same size as these wheels.... the only thing is they seem a little heavy dont you think?
chtucker
chtucker
Kirkland, WA
FJ Cruiser
They have a special feature that I can't share yet.
HoosierDaddy
__ Eric
I went on the assumption the offset was positive as there was not a minus sign.
You should probably verify that just to be safe.
Jr87mustang
Josh
Northern Cali
After seeing a stock steelie wheel with 35s on it and no spacers I'll believe anything will fit on this beast.
Silver-Bolt
Eureka, MT
38lbs/ea? I hope that they are real beadlocks. However with a 2300lb weight rating and weighing 38lbs I seriously question the quality of the manufacturing.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Subscribed for the reveal.
As mentioned, this aftermarket wheel will sit 5mm (~1/4") further out over the factory wheel and they look to be hub centric as well (93.1mm hub bore) .
