Window Reset Procedure
Klunatic
F250
I have seen multiple threads on resetting the one touch open/close on the windows. There also seems to be a bit of confusion on the exact procedure. I found it in the Bronco Manual.
Resetting One-Touch Close
Carry out all steps within 30 seconds of starting the sequence.
  1. Close the window.
  1. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for two seconds.
  1. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for two seconds.
  1. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a two seconds.
  1. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a two seconds.
Note: Repeat the procedure if the window does not close when you use one-touch.
https://www.fordservicecontent.com/...d=7704&vFilteringEnabled=False&userMarket=USA
Orf
Greg
Venetia, PA
2014 Flex, 2017 F-250, 2018 Sienna
I like how all the steps are numbered 1
Just pulling your chain ...
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Search function for the win.
Just noticed this morning:
Ford Bronco Window Reset Procedure 21B43D4B-F91B-422D-B4EC-CBC0B8644A55
SquatchWatcher
Chuck
NE Ohio
2022 Explorer ST
It worked!!!
MrParticular
New York
davidlauterbach.com
2022 2.7 Bronco, 1989 5.0 25th Anniversary Mustang
This worked for me too... rear passenger window stopped dropping down when opening the door and got stuck wedged open like @redone17 's photo.
jrbreeland
Atlanta
My window isn't closing because it bounces back open as soon as it closes. So should I just hold the button regardless of where the window is in order to reset it?
obx_rick
Rick
Apex, NC
2014 Ford Edge SEL
Man I hope this works!! I've already had the Ford Dealer recalibrate my windows twice and now two of them are refusing to roll up all the way.
Service Rep said it happens if you put pressure on the window while opening or closing and I sure as heck am not doing that, but I think sometimes it gets messed up when you roll up the windows on a bumpy road (or non-road).
Bronco15
UAE
2.7L sas 2drs
I can confirm that the same issue happens when I am on a bumpy road, especially off-road while moving. Fortunately, it's fine once I come to a complete stop
duckgumbeaux
Louisiana
2021 F150 Platinum
  2. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for two seconds.
  3. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for two seconds.
  4. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a two seconds.
  5. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a two seconds.
Thank you for this post. It definitely worked
PullMeOverRed22
Orange County, CA
2022 Wildtrak
Yes, follow the procedure from the OP. Mine did this exact thing on Wednesday.
Area51BS
Ron
Badlands non SAS 4dr 2.3
After 11 months I just had my first window issue. Drivers window wouldn’t one touch auto close. Just ran it down and held to 5 then up and held to 5. Works again.
Guess they needed to reinvent power windows.
HoosierDaddy
Indiana
Remember what happened when they tried to re-invent the removable hard top?
LOL!!!
