Wiring for devices running only when engine is running.
wintoon
Samuel
Mexico
Hello,
I would like to wire up a device that can only run when the engine is running. Is there a terminal somewhere that is HOT only when the engine is running? Can I wire a relay there (very little power) and use that to wire from the battery to my device?
Thanks!
Sam.
N9WXU
Joseph
Vail, az
‘55 Willy’s, Liberty, F-150, Transit, ‘22 Bronco
You might consider using a voltage controlled switch such as this: http://www.aprsworld.com/apo3/
With the thresholds set correctly, it will be active while the engine is running and inactive 10 minutes after the engine stops. The 10 minutes should cover the autostart/stop feature. The voltage threshold and the delay can be set with dip switches.
wintoon
Samuel
Mexico
Thanks! That's a great idea.
jasonkosi
Jason
Chilliwack, BC, Canada
I would avoid using a voltage switch like this. Modern cars voltage fluctuates a lot when driving, in my Bronco it’s anywhere from 12.7 to 15.1, any higher than 13 and that switch will turn off, along with any accessories connected to it. OP should instead use a fuse tap
wintoon
Samuel
Mexico
A fuse tap in the engine compartment would always be on correct? All fuses are always hot I believe?
Also, in general, if your alternator is working correctly you should have a pretty steady voltage coming from your engine I believe. There's always a difference between battery voltage and alternator voltage.
The switch will turn OFF when the voltage is lower than the set voltage. I believe if its set to 13 it should work nicely.
jasonkosi
Jason
Check the owners manual for what circuits the fuses are for. You will need to test them to know which are always hot.
Bschurr
NY
Hello,
Thanks!
Sam.
Fuse #35 under the dash is unused and it is switched power (only on when the vehicle power is on). Use a fuse tap and you are all set.
wintoon
Samuel
Mexico
Thanks. Do you happen to know if there are any switched power fuses in the engine bay?
Donkeygyrl
Sheri
San Francisco
Bronco on order
I used the swaybar disconnect on mine ,I have a base .
EveryDayBronco
Motorcycle
Hello,
Thanks!
Sam.
Yes you can.
Power for the relay can come from anything but if it was me I'd tap into the power for the 12v lighter socket.
I'm assuming you did't select the aux switches when you ordered??
wintoon
Samuel
Mexico
Not an option here. It was either the "nice" OBX or the "rugged" BL. I went with nice because I don't do much off-roading.
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
I tapped into #22 - the 360 camera for my backlights. Only hot when the key is on.
wintoon
Samuel
Mexico
Thanks!
