Rough Country Hidden Winch- release/engage access
Bellime
Keith
2022 Ford Bronco
Before I start tearing my installation of the RC Hidden Winch up, I wanted to check to see if anyone else has engineered a method of using the release/engage lever on the winch?
dgorsett
colorado
F250, Mustang, Explorer
I built a rod to operate the clutch and store on the radiator mount. It works with my Rugged Ridge 9000 because it uses a horizontal T handle that lifts and rotates 90 degrees to engage. It may not work with others that angle, it might slip off. Some have modified to have a permanently mounted extension.
Bellime
Bellime
Keith
2022 Ford Bronco
Thanks for sharing, this is the direction I was going. I will keep this thread up to date.
