What did you do TO / WITH your Bronco today? 👨🏻‍🔧🧰🚿🛠
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
RoLyMa27
Rodney
SloKart, TX
21 Bronco, 22 Maverick
Took Pokey out to Rock Candy Mountain to stretch his legs
Coming down this trail in Baja Mode got a notice that my passenger rear was losing pressure. Found a spot to turn around and found a flat spot to put the spare on
good news, if you were wondering is that the scissor jack did its job perfectly. Bad news is now I’m waiting at the tire shop for the repair. TPMS in the spare did not work correctly, so I will need to check into that but all in all not too bad of a day………
Looks like Pokey is in search of Gumby.
cynicalrider
NJ
First gen taco
Added turnoffroad's rear window Molle panels
https://turnoffroad.com/collections...cts/2021-ford-bronco-rear-window-molle-panels
Two issues with these panels, but other wise pretty nice
Issue #1 - missing 2 bolts for a hardtop install. They promptly sent me 2 additional bolts, but it seems these bolts are not included by default
Issue #2 - the trim piece does not sit correctly after installing the bottom bracket
Other than that they turned out pretty nice
You’re going to have to trim them a bit to get them to sit flush.
If it is taking advantage of the soft top mounting points which it looks like it partially does, the soft tops have different trim that are notched out already.
Shawn_1121
Shawn
Hudson, NH
22 Bronco OBX A51
installed. AAL Spare Tire Mount + Oracle Brake Light Ring + @DoYouBronco / HammerBuilt Tailgate Reinforcement. Added Roam 95L with Mounts and MaxTrax
gaaangs
Ohio
Jeep
Swapped out the stock silver Badlands wheels with Wildtrak wheels I got from someone on this sub.
Blacked out Bronco and Ford logo. And new trailer hitch.
These wheels are 1000x better than those awful stock Badlands ones. Now I just need to wash her up, it's been awhile and she's a mess.
Jwells104
Jameson
Austin, Tx
Looks amazing and considering something similar. Any noticeable sag or creaky noises coming from the tailgate with the added weight?
Shawn_1121
Shawn
Hudson, NH
22 Bronco OBX A51
no issues to report
Kinetic
Josh
Savannah GA
2024 Bronco Raptor
Started on some upgrades.
https://kanseiwheels.com/products/kansei-roku-truck-black?_pos=4&_sid=b2ae48a1d&_ss=r
Kansei Roku wheels 17x8.5 o offset. No poke though. Weight on home scale was 24.2 lbs.
Putco Luminex DRL lights. Replaces factory hood tie downs. Integrated turn signal, marker lights.
Stuby antenna, a must.
Bulletpoint phone holder.
Also some top and accessory bracket rubber insulation to kill wind noise. Will post some pics later. Was able to cut down about 30-40% with 20 minutes and $20.
mpeugeot
Well I didn’t do this today… but I finished up the exterior of my Wildtrak a couple of weeks ago. Still have some touch up to do on the outside and the inside, but I love it.
The product is Monstaliner. Is similar to undercoating and a smooth to bedliner. No lore scratches on the trail! The color I chose his desert sand. They have 39 colors available online. It can be rolled or sprayed on with their Shutz gun and an air compressor at a rate of 20-100 psi. Prep work is simple, but a little un nerving. Door jams, and interior metal is prepped with sandpaper with a max grit of 320. Exterior panels are prepped with a brown or red scotch. Bright pad. All services get wiped down with MEK and a clean cloth. Allow approximately 30 minutes for the chemicals to evaporate and then begin the application process.
If anyone has any questions, feel free to DM me. This is the third vehicle I’ve done with this product, but the bronco was the only NEW vehicle I’ve ever sanded down!
Built Wild…. STAY Wild!
Ford Bronco What did you do TO / WITH your Bronco today? 👨🏻‍🔧🧰🚿🛠 IMG_0365
I love how this looks, when my paint eventually needs replacement, this is the answer.
grayshadow
Charles
Humble, Texas
Exploring the Baja Divide in Baja California Sur
WheresMyBronco
Los Angeles
2023 Badlands
Such a nice color. Got any pics/extra info on the rubber insulation you added? Especially around the accessory covers
gaaangs
Ohio
Jeep
Interested in wind noise reduction.
