What did you do TO / WITH your Bronco today? πŸ‘¨πŸ»β€πŸ”§πŸ§°πŸšΏπŸ›
BD6G
Everglades
IN
24 Bronco
Everglades
Expanding on @Footer's questions... what's the access like with the top on? I see it flips down, is it easy? Been eyeing the Pura Vida one but the flip down is nice.
Although I do like the option of the recovery board mounting on the Pura ones.
Access with it up is tight against the roof, there are two latches one on each side to release it to fold down. It is MOLLE on the bottom so you should be able to mount your recovery boards there however it will then cut into your line of site if that’s an issue for you.
Footer
NJ
2023 Bronco
It tucks up completely out of the way of your line of site. I absolutely love it, I have gear ties that I’ll use when topless to secure items. It still works with the top lift pro. Just fold the tray down and the lift slides right in. Next time I take the top off I’ll post an updated picture showing how it looks. It is one of my favorite pieces from them hands down.
Ford Bronco What did you do TO / WITH your Bronco today? πŸ‘¨πŸ»β€πŸ”§πŸ§°πŸšΏπŸ›  IMG_5266
Thanks a lot for the info ! You can barely tell it is there in your picture. I have the Toplift Pro as well so great to hear it still works with that ! Think that is the clincher for me !
I was eyeing their foldup rear shelf as well but I'm concerned about rear visibility as well as trouble getting large items into the cargo area, this seems to check those boxes.
BD6G
Everglades
IN
24 Bronco
Everglades
Glad to help, I’ve been eyeing the lower fold up shelf as well it will probably be my next purchase from them. You will not be disappointed with the attic tray no rattles and just a great thought out design.
cynicalrider
NJ
First gen taco
Can you still get stuff in there without tilting it down if needed like the pura vida one?
Shrek27
Fullerton CA
Well fuck. My wife is getting me the pura vida sides for my bday, but this is such a nicer setup. Can you still get stuff in there without tilting it down if needed like the pura vida one?
Not sure if you had plans to mount traction boards to Pura Vida, but seems like the speakers will make that space too narrow and interfere with traction board mounting. As purely storage, the M2M does look like a nicer option.
cynicalrider
NJ
First gen taco
Yeah this is purely for recovery gear storage. I noticed on my last camping trip I need much better organization and the attic shelf is perfect because it doesn't interfere with my fridge lid.
BD6G
Everglades
IN
24 Bronco
Everglades
something thin yes but it sits pretty high up to the roof. It would be hard to access it without folding it down.
cynicalrider
NJ
First gen taco
It looks like they probably could have made it bigger but were taking into account soft top lift. For my hard top with the tilt function it would have been cool to get those extra couple of inches.
Aonarch
North GA / MT
β€˜23 Bronco OBX 2DR Lux 2.7, β€˜24 V60 Polestar
Dropped it off at the dealer for the first time in my ownership.
My doors and windows have sucked since day 1.
The passenger door takes a lot of effort to open and close, but the body lines look good. So it isn't like the latch position or door position needs to be adjusted.
Then on Monday my drivers door finally sagged into the fender. I've been having problems with it for a few weeks where it sounded like it badly needed grease, or had worn out components.
Ford Bronco What did you do TO / WITH your Bronco today? πŸ‘¨πŸ»β€πŸ”§πŸ§°πŸšΏπŸ›  PXL_20240506_213919987
Driver's door shut, Look at the alignment!
Ford Bronco What did you do TO / WITH your Bronco today? πŸ‘¨πŸ»β€πŸ”§πŸ§°πŸšΏπŸ›  PXL_20240506_213905314
Barely opening the door puts it into the fender.
Ford Bronco What did you do TO / WITH your Bronco today? πŸ‘¨πŸ»β€πŸ”§πŸ§°πŸšΏπŸ›  PXL_20240506_213931178
Weird passenger side dent that has been there since week 1?
I have the slow window roll down that a lot of you have. I asked the dealer to flash the module.
The windows grab every time you open the door. Then sometimes they will get out of sync and smash into the body.
I started opening the doors with two hands so I can pause and let the window roll down first.
PrepVet
North Central WI
A bunch.
Dropped it off at service, hopefully in a few days I will get it back. As close to rattle free as these cars get. lol
5GENIDN
Joe
Idaho
A little OEM+. Swapped the cover. Used all supplied hardware.
Just installed mine this weekend as well!
I like it for 4 reasons:
1) easy drain plug
2) magnet on drain plug
3) heavier casting that should improve strength across the housing
4) Looks awesome!
Ford Bronco What did you do TO / WITH your Bronco today? πŸ‘¨πŸ»β€πŸ”§πŸ§°πŸšΏπŸ›  Glute Day
WheresMyBronco
Los Angeles
2023 Badlands
Please keep me updated on the passenger door issue and what they do to fix it if possible. My passenger door takes more effort to open/close as well and I can't seem to figure it out, but I also don't want to take it in because I'm worried they'll ruin its alignment.
Aonarch
North GA / MT
Will do!
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
1) easy drain plug
4) Looks awesome!
6) Should aid in heat dissipation
Perks all around!
